Old 03-04-2003, 10:36 PM   #1
Turbo GC4
Member#: 28555
Default L Motor... shot?! Please help
Got an Impreza L. bought it a few months ago. It seems to eat about 3 qts of Oil a month. I try to keep an eye on it. I dont worry about it much because I am likely going to do the ej22t swap.
Today I was driving it semi-hard and it started making a nasty sound, like rocks in the motor. I got home and checked the oil, and it didnt read. Added a Qrt, still didnt read. Added 2 quarts, and it read. Added the 3rd quart, and now it reads fine. But it still makes the rock sound. I assume I have internal damage now.
So I think its time to do the swap. Sound like it is dead? Should i even drive it now? I wasn't prepared for the swap yet.
Turbo GC4 is offline   Reply With Quote
Old 03-04-2003, 11:23 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Without hearing it myself, you probably spun a bearing (likely a rod bearing) and you are hearing the sound made by the metal to metal contact while the engine runs.
If you drive it, it will die at some point, possibly the next time you start it.
Sorry.
Old 03-04-2003, 11:52 PM   #3
Turbo GC4
Member#: 28555
Think this will result in head damage? I would like to use this head on the next block if possible...
Old 03-05-2003, 01:10 AM   #4
Turbo GC4
Member#: 28555
another thing i noticed... maybe it makes no difference...
if i am in nueutral and rev the motor, i only hear the ticking between 2000 and 2500 RPM
if i am driving, i only hear the ticking if i give it enough throttle to start accelerating.
if just cruising, no change in velocity, i dont hear any ticking.
Old 03-05-2003, 01:11 AM   #5
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
With the (probably correct) assumption that you ate some rod bearings, your head is going to be alright. Worst case scenario, you break a rod end and there is the possibility of bending some valves. But that chances of that happening are pretty slim...
-Brad
ChicksDigWagons is offline   Reply With Quote
Need Help Motor Noise......PLEASE HELP Rexxin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-30-2009 08:49 PM
Broke a part off the sprocket, is it shot? PLEASE HELP! 96GreenLX Service & Maintenance 8 01-01-2009 08:46 PM
brakes shot! please help decide! urbanachiever Brakes, Steering & Suspension 14 01-21-2005 04:58 PM
bad ticking after new STi motor install...Please help! Blugin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 12-23-2003 09:06 PM
Is my motor toast?? PLEASE HELP! babyjaco Normally Aspirated Powertrain 9 12-17-2003 11:59 AM
