Old 03-05-2003, 01:12 PM   #1
wighti
Member#: 15345
2001 2.5RS GC6 sedan
S.T.M.
Default 89' Subaru RX turbo--Bigger turbos??
I might be buying a 89 Rx tubo 5-speed.
Does anybody know if I can get a bigger turbo for this car?
Please let me know if I can and where I can get one.
Or maybe some place I could have the stock turbo rebuilt and worked.
Thanks alot.
Sean
wighti
wighti is offline   Reply With Quote
Old 03-06-2003, 01:55 AM   #2
vinster02
Member#: 7888
02 wrx
WR Blue
Not sure about the turbo replacement, But a neighbor had one that was pretty modded out ,it was one bad motha'. If I can find one in my area I'm all over it.
vinster02 is offline   Reply With Quote
Old 03-06-2003, 07:12 AM   #3
EJ22T
Member#: 26603
1994 EJ22T powered-
majic carpet, Boo yaaa...
Wern't the RX's equipped with RHB5 aka (IHI VF-10) Turbo's? Same as the Legacy turbo? If so then you could shove a TD05-16 on there or any VF series made for Subaru's. And you'd have a serious power package.
Mark,
EJ22T is offline   Reply With Quote
Old 03-06-2003, 10:32 AM   #4
wighti
Member#: 15345
S.T.M.
I test drove it yesterday and it runs real good
I'm not sure what turbo it has but when I bring it home I will clean up the engine and try to find out. IF, it stops raining.
One thing though, it needs some front rotors.
Does anybody know if the RS rotors and rims will fit the RX?
Then I could just buy new brakes for my RS and put my RS brakes on the RX. (my excuse to buy something new for my car)
Thanks guys,
PLEASE!! if anyone has any more info about this car let me know!!
Old 03-06-2003, 10:56 AM   #5
Mephiska
Member#: 17560
2013 STI 5-door
Satin White Pearl
Since when has rain ever stopped a subaru? Hell, I take wet pavement as a reason to accelerate from stoplights simply because it feels like I'm saying a big F.U. to newton and his so called "laws of physics"
Mephiska is offline   Reply With Quote
Old 03-06-2003, 11:26 AM   #6
wighti
Member#: 15345
S.T.M.
Your absolutely right! Rain has never stopped a Subaru but it will stop me from standing out in it just to clean up the engine.
Old 03-06-2003, 11:55 AM   #7
XT6Wagon
Member#: 524
04 STi
Default ...
I'd look at a Legacy turbo turbocharger which is a fair bit bigger, or a 87-88 T-bird turbocharger. The Legacy one will require the upper flange on the crossover pipe (header) to be changed, as will the T-bird turbo, but from what I've heard you can use a downpipe from teh leg turbo where you would have to make a custom one for the T-bird turbo. T-bird turbo is bigger and uses a garret T3 flange setup IIRC so upgrade path from there is better. Both turbos are IHI's
XT6Wagon is offline   Reply With Quote
Old 02-26-2006, 05:14 PM   #8
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
bringin back a very old post. For those of you looking to mod a older Subaru more like the '80s, the TD04 will fit onto them with minor mods done to the uppipe and then you can use an aftermarket downpipe. Also, you can add in the WRX top mount intercooler too. I'm currently putting this setup on my '89 RX which will be runnin great this evening.
Caboobaroo is offline   Reply With Quote
Got a ride in a white subaru RX turbo tonight Handsdown Mid Atlantic Impreza Club -- MAIC 24 01-15-2013 02:31 PM
LOOKING TO BUY VF39 STI Turbo Or other bigger turbos and Bigger than STock Top Mount alieus RMIC Private Classifieds 2 08-03-2007 02:17 AM
Got a ride in a white subaru RX turbo tonight Handsdown Off-Topic 9 08-27-2003 03:16 AM
('93-'01) I need pix and specs on an 88 Subaru RX Turbo! BrysImpreza Impreza Forum 7 03-07-2003 02:19 PM
FS: 1985 Subaru RX Turbo Sedan Dennis ex24 Tri-State Area Forum 0 12-22-2002 01:13 PM
Message Board Statistics All times are GMT -4. The time now is 06:19 AM.
