Old 05-27-2001, 10:47 PM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Post Rattle from WRX subaru 4 pot calipers??? HELP!
Just got a front set of 4 piston Subarau calipers from ralitech - - - they are installed with two silver pins on each side which have cotter pins holing them in
They are very loose and they are making a rateling sound that si driving nuts
Is this a normal situation or is something wrong - - - -
Does anyone know anything???
Thanks for the help - ?
alfriedesq is offline   Reply With Quote
Old 05-28-2001, 08:22 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Post
Ya know, I'm getting a "something's loose" sound from the front end too, ever since I installed the 4-Pot's. I think it's just something you have to live with. I DID notice that after some hard driving, and getting the brakes heated up, it goes away for a while. I assume because the heat causes everything to expand and tighten up.
Old 05-28-2001, 09:33 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
Did you get the anti-rattle clips with them?
Sounds like they are missing.
ANZAC_1915 is offline   Reply With Quote
Old 05-28-2001, 11:43 AM   #4
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
Post
Glenn-
Are you serious? Anti-rattle clips? I'm planning the 4 pot upgrade too, where the heck do I get these?
lbk16 is offline   Reply With Quote
Old 05-28-2001, 12:57 PM   #5
Jay_UK
Member#: 296
Post
They are silver (shiny) and a cross shape (two legs longer than the others - like a crucifix).
The two long legs locate under the pins, the two shorter legs press down onto the pads, stopping everything from rattling
Part number 26232FA020 (one for each side required). That part number is valid here in the UK.
J.
Jay_UK is offline   Reply With Quote
Old 05-28-2001, 04:27 PM   #6
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Post
So if I order the 4pot kit from subaruparts.com do i get these pins or not? I want these brakes but not if I'm going to have any odd sounds coming from them.
WRSport is offline   Reply With Quote
Old 05-28-2001, 10:28 PM   #7
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
Based on their website you do -- it says they don't include the shims for the back of the pad, but it doesn't mention the clips --- I seem to recall I did verify once (verbally) that it did include the clips.
Worth a call before ordering!!!!
Glenn
Old 05-29-2001, 01:00 AM   #8
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
They should come with the kit, exactly as Jay describes.
Without them you'll get a "clack clack" noise.
I suggest you contact your supplier. I know SPD and subaruparts.com supply all the correct bits with their 4 pot kits.
Glenn
Old 05-29-2001, 06:42 AM   #9
aowRS
Member#: 3852
2000 Outback
Wintergreen
Post
I installed a set of 4-pots the other week and simply forgot to install the clips. The pads made an awfull clacking noise. Then I remembered and installed the clips (intuitive). The brakes still make some of that noise but not as much. I have a feeling that I only received half of the clips - It would make sense if there was one clip per corner holding pad/shim/shim together. So right now I only have two per caliper. The part number 26232FA020 anti-rattle clip mentioned above makes sense - had the exact same thing on my last car. Would Troncalli have these and why did the kit not come with them? Does anyone have an exploded view of the 4-pot setup? I think we're allmissing various key pieces.
aowRS
aowRS is offline   Reply With Quote
Old 05-29-2001, 10:33 AM   #10
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Post
Thanks thenks thnaks so very much - its makes sence that subaru would not design something that makes os much noise - - - its very sad that Rallispec told me this et up without the propoer clips - sad
Old 05-30-2001, 05:24 PM   #11
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
EJtwentyfied -> '04 STi
Post
I just installed the 4pots today. What cross shaped clip are you referring to. I had the 4 big pins and then a clip that goes through both sides of the pins (doesn't look very stable). I also got 3 (I think I should of had four) clips that cliped in the corner of the pads. Are these the clips you are talking about? They look like they hold the pad and shim together. Installed one on the outside pad on the top and the other on the inside pad on the bottom. The right side I olnly had one to put on Does anyone have a drawing or picture.
[This message has been edited by PRODRIVEN (edited May 30, 2001).]
PRODRIVEN is offline   Reply With Quote
Old 05-30-2001, 08:26 PM   #12
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
Post
Okay, I got to drive more on the 4 pots this evening. I get that "clack-clack" noise from the front end when I go over a bump (such as a manhole cover) at a slow speed. I didn't get these cross shaped clips with my kit. Is it an emergency that I get these ASAP. Can I still drive the car without the pads or anything falling off?
I accident took off the 4 bolts behind my 4 pot caliper help. 06wrxlbart Brakes, Steering & Suspension 7 04-16-2008 03:41 PM
FS: Subaru 4 Pot Calipers + WRX DBA 2 Piece Aluminum Hat Rotors STEALTH-WRX Suspension/Brakes/Handling 22 03-04-2008 11:55 PM
FS: Subaru 4 Pot Calipers + WRX DBA 2 Piece Aluminum Hat Rotors STEALTH-WRX SCIC Private Classifieds 2 02-04-2008 07:17 PM
WTT: My STi Brembo Calipers F+R For Subaru 4 Pot Calipers F+R RicanLynk Private 'For Sale' Classifieds 13 02-18-2005 11:38 PM
Subaru 4 pot calipers, good investment? MD20 Technical Forum Archive 16 06-27-2000 03:34 PM
