Old 05-28-2001, 02:46 AM   #1
SubieKidTK
Member#: 5488
1992 Nissan Maxima
Pearl
Arrow Is the wheel upgrade worth it?
The MY00-01 wheels are pretty darn light at 16lbs., right? So is everyone upgrading simply for looks? I guess it depends on what you are shooting for. But I probably shouldn't be talking because if I had the change, I would throw some OZ P1's or SuperL's on my car too...Another question, is it against the rules to say "damn" on i-Club? <---nothing new there
Ty
SubieKidTK is offline   Reply With Quote
Old 05-28-2001, 06:03 AM   #2
sbsnyder
Member#: 2440
Post
You'll get different responses from different people. Some will say to simply upgrade your tires to something with a stiffer sidewall on your stock wheels, and others (me being one of them) will say that the 17" upgrade was well worth it.
My car handled incredibly better with my 215/45/ZR17 Toyo Proxes T1-S on Speedline Prodrive 7's. And I personnally did not noticed the weight difference at all between the stock wheels/tires and the Prodrives even though each wheel is about 5-6 pounds heavier. Not on the street or at the track.
I guess in order to answer this question properly, someone is gonna have to reply that:
1) Upgraded tires on original wheels
and
2) Upgraded wheels and tires to 17"
...and then compare the difference. I'm looking forward to seeing the responses of anyone who has done so.
Regards,
Stacey
sbsnyder is offline   Reply With Quote
Old 05-28-2001, 06:59 AM   #3
inpreza kid
Member#: 3334
Post
its really up to you. i upgraded to 17's as well. handles very well. just make sure you get a light wheel. but also you'll be spending twice as much since you have to get rims too. can easily add up to excess of $2000 for just good rims.
inpreza kid is offline   Reply With Quote
Old 05-28-2001, 07:06 AM   #4
Eric Gagnon
Member#: 46
2001 Jetta 1.8T
Post
Allot of us upgrade our wheels beacuse we wanted the next level in handling. I use to have 16's w/ bridgestone 730's and i wanted a little more response and turn in so i opted for new 17" wheels. Yes they do weigh a little more, but oh well. They track better and handle amazing. I have Prodive P7's w/ Pirelli P-Zero Asymetrico;s. Great combination and well worth the $$.
Eric
Eric Gagnon is offline   Reply With Quote
Old 05-28-2001, 07:19 AM   #5
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
Post
With 17s you have the ability to run a much better tire and any weight gain is negated by the real world gains. I went from stock 16s with 205 55s to 17s with 215 40s. My speedo is off about 3mph and that is the only negative effect of the changeover S.F.W. Corners that I once took at 45 I now take at 60, and overall stability and "tightness" are so improved it feels like a different car.
Pipercub is offline   Reply With Quote
Old 05-28-2001, 08:47 AM   #6
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Post
You do bring up a good point.
The only reason I want 17s (Volks so these 17s are gonna be lighter than stock) is so I can run the brembo kit (mmmm 330mm rotors)
but you can ask youself this:
Will spending 4G for this setup brake 3 times better than one using a 4-pot sti setup?
4G is a lot. I know adam bloom has the brembo kit with 17s Volks (iirc) and he says he was outbraking porsches.
NickSTi is offline   Reply With Quote
Old 05-28-2001, 09:00 AM   #7
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
Post
If you want 3 times the performance, you are not going to cut your 70-0 times and distances to one third of their current level. Thats is impossible.
I think a difference of even 20 feet is a big deal. Perhaps you'll drop the distance by even more than that.
The Volk TE37's are the only really light wheel I know of that they make in 17. Didn't know these came in the correct offset.
Zahnster is offline   Reply With Quote
Old 05-28-2001, 09:08 AM   #8
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Post
SE37K is a magnesium/aluminum alloy and weighs around 13lbs
Conduit is offline   Reply With Quote
Is the "torque box" worth it? ScoobyDoobieBlue Normally Aspirated Powertrain 17 04-13-2006 11:32 PM
Is the STI tmic worth it? onelife2430 Engine Management & Tuning 19 10-28-2005 11:16 PM
Is the speaker upgrade worth it? Luvmy04wrx_wagon Car Audio, Video & Security 6 03-22-2004 03:52 PM
Is the Speed Channel worth it? Rodan Texas Impreza Club Forum -- TXIC 7 05-16-2003 03:18 PM
Is the AVC-R worth it? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-10-2003 03:24 AM
Message Board Statistics All times are GMT -4. The time now is 07:14 AM.
