03-05-2003, 10:15 PM | #1 |
Member#: 13745
Vehicle:2015 STI WRB |
Help!
I was in the middle of installing my lw pulley and was doing fine until Itried removing the crank pulley. Itwouldn't budge witha 1/2 inch breaker bar, andI have no pipe around. My belts are off of my car now. If anyone wants to offer any suggestions or help it would be appreciated.
03-05-2003, 11:42 PM | #2 |
Member#: 1925
RMIC
Vehicle:01 A4 89 944s2 13 Speed 3R 99 Sprint |
use a 4 foot pipe... seriously.
03-05-2003, 11:52 PM | #3 |
Member#: 13745
I would, but I dont have a 4ft section of pipe laying around
I guess I'll just have to put my belts back on.. Last edited by joefocker20; 03-06-2003 at 12:59 AM. |
03-06-2003, 12:59 AM | #4 |
Member#: 4766
Vehicle:2001 2.5 RS BRP |
Yep, this is the hardest pully to do. You reall need a big breaker bar and just keep slammin it down (start all the way driver side and slam it hard to the passenger side) Eventually it will give loose..... it takes some work. Oh, and putting it in 5th helps a little bit
Kurt |
03-06-2003, 01:47 AM | #5 |
Member#: 13745
Damn.. Noone wants to help a fellow Subaru Owner in Colorado Springs?
03-06-2003, 02:48 AM | #6 |
Member#: 29516
RMIC
Vehicle:2005 WRX Wagon Former GC O.G. |
get Braden to do it if you are in the Springs. I don't know if he still does work but it's worth a shot if you can get a hold of him. Putting it into 5th and starting the car should work but that breaker bar thing gets scary.
03-06-2003, 03:59 AM | #7 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
Wedge the bar under the hood somewhere and click the engine over once. It should break loose easily.
03-06-2003, 05:12 PM | #8 | |
Member#: 1925
RMIC
03-06-2003, 11:32 PM | #9 |
Member#: 13745
Nevermind, I used a 4ft bar and could have broken it loose with a finger. Pretty easy install.. If you're going to do this, use a 1/2 breaker bar and a BIG Pipe.
03-07-2003, 12:00 AM | #10 |
Member#: 9861
RMIC
Dolph: It works really well. Very easy. Seen it done lots of times.
03-07-2003, 12:07 AM | #11 |
Member#: 13745
Im sure that I aligned the keyshaft properly, and tightened it enough, but if not, would I have noticed this in the 10-15 miles I drove with it on? I'm just paranoid when I work on my own car..
03-07-2003, 01:19 AM | #12 | |
Member#: 9548
RMIC
Vehicle:2004 WRX STi 10.154 @139 @ 7,000'DA |
cnstman |
03-07-2003, 07:26 PM | #13 |
Member#: 13745
DO you notice a VERY slight wobble to your pulley with absolutely no deflection to the belts?
