Old 03-06-2003, 03:37 PM   #1
neverendingmods
Member Sales Rating: (1)
Member#: 23796
2006 STi
white
Thumbs up Autospeed flex uppipe
Had Rallispec in Jersey do the install. Actually, they also had the uppipe. Decided not to go with the one I had already after seeing this one. This was the first one they got inand installed. Excellent quality. 304 stainless Iwas told by rallispec. It does not have an EGT bung but comes w/ a egt sensor fix. The flex unit is not a sleeved- thru design. But rather open like the STi piece. 3/8 thick flanges on both sides w/ studs and new nuts. Did not include gaskets. Price was $339. When you see the quality and feel the throttle response, you'd agree it was worth it. I'm sure once more of these get out there, price will come down. The increase in throttle response is seriously evident anywhere above 2500 rpm. I heard the open flex unit opposed to a sleeved style produces turbulent air. There is no hesitation or fluctuation in boost. Just HARD pulls to redline from any rpm.
Now my TXS stage 3 is complete. TXS turbo back, txs I/C(ver1), autospeed uppipe, and u-chip mapped for stage 2+tmic.
Exhaust got meaner sounding. A few more pops at throttle lift and slightly deeper. Definately louder.
neverendingmods is offline   Reply With Quote
Old 04-28-2003, 07:52 PM   #2
yuletak
Member#: 3602
2002 wrx silver
1992 kawasaki ex500
anyone else care to review this UP?
yuletak is offline   Reply With Quote
Old 04-29-2003, 12:09 AM   #3
neverendingmods
Member#: 23796
2006 STi
white
I forgot the most important thing. The flex is at the bottom of pipe(4" from manifold) rather than close to turbo. This is suppose to drastically reduce the turbulance caused by the open flex section.
Old 05-28-2003, 10:21 PM   #4
onyxhunter
Member#: 29993
how much did rallispec charge for the install?
onyxhunter is offline   Reply With Quote
Old 05-28-2003, 10:23 PM   #5
onyxhunter
Member#: 29993
Old 06-08-2003, 05:32 PM   #6
neverendingmods
Member#: 23796
2006 STi
white
$280.00. Haven't had a leak yet.
Old 06-08-2003, 05:52 PM   #7
kenchan
Member#: 15106
any CEL's?
kenchan is offline   Reply With Quote
Old 06-08-2003, 06:08 PM   #8
neverendingmods
Member#: 23796
2006 STi
white
The uppipe came w/ the front sensor fix as it is bungless. I have the txs tbe w/ mid cat. Never got a light but I do now. Waiting for sunny day to do rear O2 fix.
Old 06-08-2003, 06:25 PM   #9
wroblewskiwrx
Member#: 34373
06 evolution ix rs
machv has the autospeed uppipe on sale for $249.99 mine should be here on 6/9.
wroblewskiwrx is offline   Reply With Quote
Old 06-08-2003, 06:33 PM   #10
neverendingmods
Member#: 23796
2006 STi
white
Yeah, I'm still pissed about that one.
Old 06-11-2003, 01:21 AM   #11
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Just ordered mine today-ya'll say it DOES indeed come with the cel fix??
Old 06-11-2003, 01:23 AM   #12
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Old 06-11-2003, 01:23 AM   #13
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Old 06-11-2003, 01:46 AM   #14
neverendingmods
Member#: 23796
2006 STi
white
For the front, Yes. If you have a turbo back exhaust w/ one or less cats, may want to buy rear O2 fix. Only $20.
Old 07-31-2003, 04:41 PM   #15
bart'03
Member#: 34889
03 WRX Wagon
I bought the Autospeed Uppipe from Vivid on sale for $200. I installed about 3 weeks ago.
The pipe looks really nice, as the previous review said, the flex unit is at the manifold end instead of the turbo end. The flex is an accordion style sleeve fitted into the pipes on both ends and the pipes are sleeved into the flanges and welded on both sides.
The pipe installed well and I have no leaks and no cels after three weeks (using the supplied resistor). I am also very pleased iwth the performance, the turbo spools up about 200-300 rpms sooner than my buddy's wrx and I can definitely feel and see the difference.
Nice product. Highly recommended.
-B
bart'03 is offline   Reply With Quote
Old 09-05-2003, 01:08 PM   #16
Ride Operator
Member Sales Rating: (3)
Member#: 18710
02 GDA PSM
12 Impreza Sprt Lmtd MBP
Post small note
Just wanted to note (I helped w/the install of one of these the other day) the nuts that come w/the upper stud bolts for the piece are 17mm. I thought that was kind of weird since most of the OEM exhause bolts are 14mm. So the nuts are a little larger and we had just a little bit of an issue getting on one of the nuts on due to fitment issues with the socket we were using.... other then that small note, nice piece!
Ride Operator is offline   Reply With Quote
Old 09-05-2003, 03:04 PM   #17
KanosWRX
Member#: 17904
010 STI
Actually I just got my new STI uppipe and it does have a sleave that goes through the middle, cant see the flex joint at all through the inside.
KanosWRX is offline   Reply With Quote
Autospeed Flex Uppipe ButtzWRX MWSOC Private Classifieds 6 07-26-2006 10:18 PM
AutoSpeed Flex Uppipe ButtzWRX MWSOC Private Classifieds 1 01-23-2006 12:44 PM
PA: Autospeed Flex uppipe for WRX/STI Wagon Of Fury Private 'For Sale' Classifieds 3 04-24-2005 01:22 PM
Autospeed Flex Uppipe Mr. Fancypants Private 'For Sale' Classifieds 8 11-21-2003 06:20 PM
Autospeed Flex Uppipe with 5 piece gasket set Mr. Fancypants Private 'For Sale' Classifieds 9 11-09-2003 12:33 PM
