Old 03-07-2003, 09:17 AM   #1
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Default Got a CEL and car sounds like a tractor
Cruising into work today my car was running great. In the parking lot I make a left hand turn and heard a quick crunch sound. Immediately after my car got really loud and it sounds like a tractor. I looked down and I've got a blinking CEL. It sounds like the loud noise is coming from the engine bay and not from my tailpipe.
I'm not sure if I should try to drive it to a dealer. Any hints on what I should be looking for or what could be wrong? Thanks in advance for the help.
D-Rock is offline   Reply With Quote
Old 03-07-2003, 09:59 AM   #2
spt_impreza
Member#: 3004
blinking CEL is bad.....IIRC...it may be in "limp" mode now. It sounds like you may have ripped of broken something off the bottom of the engine/exhaust. the reason for the tractor sound...
Have a peek under there and see if you can see any holes or stuff like that.
spt
spt_impreza is offline   Reply With Quote
Old 03-07-2003, 11:00 AM   #3
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
i ran my car with open headers for one day waiting to get my exhaust done. sounded like a tractor, and i mean almost friggin identical. sounds like you ripped your exhaust off somewhere up by the engine bay. may have damaged something else too, cuz i only had a steady CEL when my exhaust was off.
jasona is offline   Reply With Quote
Old 03-07-2003, 01:14 PM   #4
D-Rock
Member#: 3651
2001 2.5 RS Coupe
UPDATE
I had my car towed to the garage because I was told not to drive on a blinking CEL. Before my car was put on the flatbed I had a look in the engine bay. It turns out my car had blown a spark plug out of the engine.
I lucked out and it didn't damage the threads. The spark plug it blew out was toasted. I have Bosch Platinum plugs and one of the four tips had broken off. Another part of the plug was broken off inside the plug wire. So I ended up getting new plugs and plug wires.
My car sounded like a lawnmower/tractor without the spark plug out. I thought for sure it was something with the exhaust system. This all started after getting a Cobb intake. I guess the intake is do it's job well.
Thanks for the replies.
Old 03-07-2003, 01:32 PM   #5
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
Exclamation Whoa....
Any idea how/why the plug would get blown OUT of the engine? How could the spark plug get blown out without damaging the threads, unless it wasn't screwed in tightly??
BlueTDimly is offline   Reply With Quote
Old 03-07-2003, 01:51 PM   #6
BoyRacer
Member#: 31411
2001 RSTi, Cayman S
BRP Subaru, Black Cayman
Default Re: Whoa....
I'm guessing here, but maybe a defective plug? Bad threads? Were the threads sill in the block or was the whole thing blown out? I'm very interested.
MGB
BoyRacer is offline   Reply With Quote
Old 03-07-2003, 02:00 PM   #7
D-Rock
Member#: 3651
2001 2.5 RS Coupe
I had put in the Bosch plugs about 10,000 miles ago. I guess over time they had worked their way loose. I was lucky and the threads on the block were fine. When the mechanic put in new plugs he mentioned that some of the other plugs were also loose.
I don't know why but after adding Cobb intake the plugs decided they didn't want to be in the engine anymore. It could be my fault for not tightening the plugs enough. I just thought it was odd that 10,000 miles later it becomes an issue.
I'm just happy that I have my car back and working.
why does my car sound like a tractor when it's below freezing doubledribble Normally Aspirated Powertrain 22 01-29-2005 02:21 AM
Help! Heard a "pop" and car sounds like an old bug! vitaminwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-08-2004 09:26 PM
"Your car sounds like those ones in The Fast and the Furious" MattDell Off-Topic 18 01-22-2004 09:16 PM
So my car now sounds like a tractor.... Scoobyslack1 Mid West Subaru Owners Club Forum -- MWSOC 7 09-10-2002 11:52 AM
