Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 04-17-2001, 09:12 AM   #1
25psi
Member#: 3086
2001 2.5 RS
Cool Here is tire sizes chart. No more tire size Qs? Yeah, right!
Here we go guys!
Stock Tire Size Vs. Aftermarket Upgrade Sizes
Not Like I mind answering a size Q gazilion time, it just seems like I am runningout of the hours inthe day to do so.
Enjoy!
Eugene
25psi is offline   Reply With Quote
Old 04-17-2001, 09:14 AM   #2
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
Post
Nice work Eugene. Looks like 225/45R17 are the ticket for the WRX.
Ginseng is offline   Reply With Quote
Old 04-17-2001, 09:28 AM   #3
Scottie
Member#: 2080
06 Impreza Wagon
Red
Post
Are those calculated numbers or numbers taken from a manufacturers data sheet for a specific model of tire? From the data sheets I've seen, different model tires (even from the same manufacturer) can vary quite a bit for the same size.
Scottie is offline   Reply With Quote
Old 04-17-2001, 09:44 AM   #4
25psi
Member#: 3086
2001 2.5 RS
Smile
Scottie - Those #s are calculated.
You are right different brands do vary a little bit. Ohh, well. I am nice but not THAT nice to do THAT much of research and compare same sized tres from different barnds.
Eugene
Old 04-17-2001, 11:33 AM   #5
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Post
So you can't just +1 and keep the same exact diameter?
garface is offline   Reply With Quote
Old 04-17-2001, 11:39 AM   #6
jlyttle
Member#: 2815
2004 Forester XT 5sp
Post
Width?
jlyttle is offline   Reply With Quote
Old 04-17-2001, 11:45 AM   #7
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Post
Thanks Eugene! Going on my wall right now.
Tkacik is offline   Reply With Quote
Old 04-17-2001, 04:44 PM   #8
25psi
Member#: 3086
2001 2.5 RS
Post
Bumpy
Old 04-17-2001, 05:03 PM   #9
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Post
Ask Subie Gal about width the Dunlop 9000 she had were way fatter than RE92's for the same tire size.
I would not trust a calculator for final tire selection. It is fine for finding overall diameter but not for overall width. You have to go from the manufacturers data sheets.
david2z4 is offline   Reply With Quote
Old 04-17-2001, 06:18 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
David2z4 is correct - my 205/55x16 RE730's are much wider than the same size RE92's
Also, search my links at www.imprezars.com for "calc" or "calculator" and you'll find a bunch of tire size and hp calcs, etc...
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 04-18-2001, 12:11 AM   #11
25psi
Member#: 3086
2001 2.5 RS
Post
Width of what?
225/45/17 tire supposed to be 225mm.
Ok, ok. I see you guys want EVERYTHING!!!
Lazy a$$es. All right! I'll hook you up!
Eugene
Old 04-18-2001, 12:54 AM   #12
25psi
Member#: 3086
2001 2.5 RS
Post
http://25psi.topcities.com
Ok, go there and see for yourself pretty much EVERYTHING you need to know before doing wheel/tire upgrade!
Eugene
Old 04-18-2001, 06:56 AM   #13
25psi
Member#: 3086
2001 2.5 RS
Post
Hey guys.
I am perfectly AWARE of manufacturerers differences.
This page was constructed as a GENERAL GUIDE and not "Tire Size Bible". If anyone has very specific tire in mind they shurely MUST contact tire manufacturer to find its EXACT dimensions.
I constracted this page simply for the reason of people asking same question over and over again about swaping rims and tires. Now those people have a place to take a peek before proceeding farther.
Or of course they can just ignore it if they know it all like some of us.
Eugene
Old 04-18-2001, 07:08 AM   #14
Canbaru
Member#: 3475
2004 WRX Wagon
Post
Hi Eugene - sorry but I see no 215/40R16 in your chart (apologies to Colin) but I think (I'm going to have to buy and prove - after learning how to drive first of course) this is the best performing 16" tire
Also I feel it is important to mention in your guide that you need a slightly wider rim width as aspect ratio decreases - e.g., 225/45R16 will fit on stock 7" RS rim but not 225/40R16s.
Thanks again for great tool to reduce basic questions!
Tim
Canbaru is offline   Reply With Quote
Old 04-18-2001, 07:17 AM   #15
25psi
Member#: 3086
2001 2.5 RS
Post
Canbaru
The sole reason 215/40/16 is not there cuz it is WAY too off from original size. As much as -8.5% off. It is WAY TOO MUCH difference. That is why it did not make it.
What do you mean BEST PERFORMING tire? It all depends what you want your tires to do. Snow tire, mud tire, tarmak tire, cruzing tire, etc, etc, etc. Also thre is a gazilion of things one would need to consider before buying a tire. Do you want quite ride or better grip? Are you willing to sucrifice some of that grip for wet handling? What about when temperature drops below 25? How important long thread life? Etc, Etc, Etc.
And as for widertire-belong-on-wider-rim. I do have a GENERAL guide on that page. Keep reading.
Eugene
Old 04-18-2001, 09:20 AM   #16
jlyttle
Member#: 2815
Wink
"Selection of a wider rim, from within the approved range, (T & RA tables) stiffens the sidewall and improves handling at the expense of handling."
What does this mean?
Old 04-18-2001, 01:59 PM   #17
25psi
Member#: 3086
2001 2.5 RS
Post
Opppsie.
It means I ficked up a little bit.
All fixed now.
Eugene
Old 04-18-2001, 02:58 PM   #18
megatron
Member#: 4212
2002 Impreza WRX
Post
Thanks for the GREAT page. I finally understand offset.
I wasn't aware that a 225/45/17 tire would be closer to the stock diameter than the recommended 215/45/17. What gives? I was specifically thinking of getting Kumho Ecsta Supra 712s. Anyone with knowledge of these tires, which would be better, the 225s or 215s? Seems like most people go for the 215s.
Thanks,
Andy
megatron is offline   Reply With Quote
Old 04-18-2001, 03:29 PM   #19
25psi
Member#: 3086
2001 2.5 RS
Post
There is really no better or worse. They are just a bit different.
Eugene
WRX is a track virgin no more... MasterKwan Mid Atlantic Impreza Club -- MAIC 20 10-03-2007 09:05 AM
My wrx is no more. It is an ex-wrx. No more for shore. Dynobyte Southern California Impreza Club Forum -- SCIC 66 07-26-2006 08:14 PM
Interesting... Just installed Whiteline rear Control Links, and no more tire rubbing Kostamojen Brakes, Steering & Suspension 6 04-14-2004 08:15 PM
Stoned on paint fumes...the rally car is now half painted. No more primer (almost)! Sean New England Impreza Club Forum -- NESIC 30 09-08-2002 09:33 AM
Bulb size chart? BlueFlash Newbies & FAQs 2 08-27-2002 11:27 AM
