Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 03-07-2003, 03:01 PM   #1
stevedood
Member#: 13841
02 WRX WAG
Default check that swaybar...
...just a friendly reminder to check those sway bar bolts for you guys that have done your own installation... particularly those at the top of the endlinks for the rear sway bar and make sure they are tight...
my WL sway bar & MRT endlinks were abit loose despite being set to factory torque settings & run for 6 months. I could have had a really bad day had I not looked at them the other day and noticed a loose nut.
-steve
stevedood is offline   Reply With Quote
Old 03-08-2003, 02:31 AM   #2
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Mine came out on the passenger side - also torqued to spec.
AntiochCali is offline   Reply With Quote
Old 03-16-2003, 11:13 PM   #3
hoche
Member#: 22072
1999 OBS
Do you have nylon locking nuts? I just put some MRT's on my front swaybar and they came with nylon locknuts. I'm wondering if those will hold, or if I need to put a bit of threadlocker on them.
hoche is offline   Reply With Quote
Old 03-17-2003, 02:47 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I did a swaybar check over the weekend, my kartboy endlinks were installed wrong! (whoops) So i fixed it quick (15 minutes) and now its all good
Do make sure to check every now and then though...
Old 03-17-2003, 11:40 AM   #5
JonnySubaru
Member#: 17901
Thumbs up
Theres this cool stuff.... they call it Loctite! =)
JonnySubaru is offline   Reply With Quote
Is it rude to write a check that you know is going to bounce? Jake1050 Off-Topic 31 03-22-2008 05:09 PM
Final Swaybar poll before I hit the Check out button Liam Newbies & FAQs 24 08-28-2007 09:40 AM
Quick check that I have the right filter leecea Service & Maintenance 1 09-13-2006 04:05 AM
FYI: If you T bone a car and run, check that your radiator isn't leaking Sharkbait South East Region Forum 20 04-08-2006 12:50 PM
Guess that Swaybar!!! Shini590 Brakes, Steering & Suspension 4 05-23-2004 11:55 PM
