Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 03-07-2003, 03:38 PM   #1
DJ 9iron
Member#: 11349
2011 2013 Peterbilts
White, Black
Default CEL (messed up gas gauge)
Ok, this is the second time this has happened. I didn't do anything to the engine or any electrical work.
Scenario; Gas gauge drops to E, light comes on, CEL comes on.
Reset ECU, all is fine.
It's happened twice now, causes?
DJ 9iron is offline   Reply With Quote
Old 03-07-2003, 05:10 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Get the code pulled next time.
could be failing fuel sending units.
Jay
Old 03-07-2003, 05:13 PM   #3
DJ 9iron
Member#: 11349
White, Black
Is that common? I have 46k on it.
Old 03-08-2003, 10:12 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Could also be the evap emissions solenoid going or a leak in the evap system. Personally, if it only happens when the gas light comes on... don't let the tank get that low .
Old 03-08-2003, 01:41 PM   #5
DJ 9iron
Member#: 11349
White, Black
No, no... The gauge will be at half a tank or more, then just drop real fast (5 seconds) to E. The light will come on, then the CEL will appear. The tank isn't empty. And what is evap emissions?
Old 03-10-2003, 09:26 AM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
DJ, don't worry about the evap emissions... you've just given more info and evap is NOT your problem. You've either got a bad sending unit, bad gauge, or bad float on your fuel pump. Get the code pulled from your local Autozone, Pep Boys, etc and then we can figure out what the best fix is.
Old 03-10-2003, 11:37 AM   #7
DJ 9iron
Member#: 11349
White, Black
ok, thanks. It hasn't happened for a few days, but the next time it does I'll be sure to get it pulled. Thanks.
UP and DP install, car messed up bad!! Lurkin4Life Newbies & FAQs 50 02-17-2008 03:40 AM
Messed up with touch-up paint 04luchini Car Care & Detailing 14 05-28-2007 07:31 PM
so i go to LA mess up my brakes and end up on the Fast and the Furious set gokou006 Southern California Impreza Club Forum -- SCIC 4 03-18-2003 07:27 PM
Someone messed up my baby!!! Saw Jai Bay Area Impreza Club Forum -- BAIC 10 12-09-2000 12:46 AM
