Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 03-07-2003, 06:20 PM   #1
jskho
Member#: 11864
Default need help with projectors & HID
would anybody be able to give me help with my HIDs. i think i got a bad set of projectors.. the focal point is off. the light pattern with the stock H1 bulb throws same light beam as the ones with HID.. there is a cut off at top and then a cut off at bottom.. is it me or is the projector defective.??
james
jskho is offline   Reply With Quote
Old 03-07-2003, 10:04 PM   #2
Pat Green
Member#: 5818
2002 WRX, '72 510
V is for Victory, Hippie!
Yeah, they look a little buggered up. It almost looks like they aren't seated deep enough. One thing you can do to check alignment, is to keep the back cap off and move the lamp around (without the clip on) while your headlights are on. You'll should be able to find the sweet spot. When I put mine in, my right headlight was hosed like yours. I did some grinding on my headlight, and found that wasn't the way to go. I ended up shimming the one side of the bulb, and now it lines up perfectly. Good Luck!
Pat Green is offline   Reply With Quote
Old 03-08-2003, 01:08 AM   #3
WagonRX
Member#: 7480
WRB WRX 5 Door
VS2 12.9 @105 MPH-4EAT
What projectors do you have?
Russell
WagonRX is offline   Reply With Quote
Old 03-08-2003, 06:08 AM   #4
jskho
Member#: 11864
i got the STI EDM projectors
Old 03-08-2003, 01:07 PM   #5
WagonRX
Member#: 7480
WRB WRX 5 Door
I thought those had an "E" pattern like the Morrettes. Did the HID bulbs have a metal shield? If they did, they can cause some issues with projectors.
Russell
Old 03-08-2003, 01:47 PM   #6
jskho
Member#: 11864
the housing of the projectors have a metal plate.. in the middle is a rectangular hole for the bulb to go through.. to the left and right are two small holes that is use to secure the holes.
Old 03-08-2003, 06:58 PM   #7
WagonRX
Member#: 7480
WRB WRX 5 Door
I'm not 100% sure about the lights you have. PM jimhoyd because he has those and may be able to help you out.
Russell
Old 03-08-2003, 08:49 PM   #8
jskho
Member#: 11864
i emailed him already, since i got the harness through him.. he haven't gotten back to me yet..jsut came back from MPJ performance in hayward.. will try putting some washers to sit the light a bit more out or sand down the housing so the lights sit in a bit more.. will try to see which is better..
Old 03-14-2003, 06:55 PM   #9
jskho
Member#: 11864
i have tired many times to adjust the projectors.. i am
Old 03-14-2003, 07:04 PM   #10
jskho
Member#: 11864
I would apprecieat any help i can get..
need help with inspection & p0457 STi-Spec C New England Impreza Club Forum -- NESIC 10 09-22-2009 08:25 PM
Need help with UP & DP install Mr.Sparkle New England Impreza Club Forum -- NESIC 23 02-12-2006 06:28 PM
Need Help with HID Hksueprman Off-Topic 2 09-27-2005 03:24 PM
need help with hid wires - was working hybrid gti 2 Electrical & Lighting 2 02-06-2005 03:00 AM
need help with hid wrxmania Electrical & Lighting 1 12-09-2004 01:48 AM
