Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 03-07-2003, 05:41 PM   #1
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Question JDM WRX 9:1 CR Piston Design
Does anyone know what the top of the piston looks like on the JDM WRX with a 9:1 compression ratio? Is it flat like the STI or have a dish? Anybody happen to have any pics?
JD
webmaster@wrxhackers.com
www.wrxhackers.com
wackie is offline   Reply With Quote
Old 03-08-2003, 12:49 AM   #2
zaxrex
Member#: 9898
Water Injected Blue
Default Don't know about the comp ratio, but
that was from a post here
zaxrex is offline   Reply With Quote
Old 03-08-2003, 01:15 AM   #3
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Thanks for the comparison, but I was looking for the JDM WRX that is a 9:1 compression ratio. If that's a piston from the USDM WRX it's 8:1. The reason being, the shape of the top of the piston is going to have a lot of effect on how much money I'm going to have to spend on gas with my new motor.
Old 03-10-2003, 12:05 PM   #4
zaxrex
Member#: 9898
Water Injected Blue
Check that link,
"the internals as compared to an EJ207 2002 JDM STI block "
for sure not a US spec STi.
Again I can't say anything to the Compression Ratio for the EJ207.
If worse comes to worse, you can contact the guys that did the write-up for more tech info.
Old 03-10-2003, 12:11 PM   #5
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
I believe the compression ratio on that STI is 8:1. The reason I asked for the 9:1 CR version is there is a version of the EJ20 in a WRX (not STI) in Japan that runs a 9:1 CR along with the TD04 turbo. I just wanted to see what the piston design looked like.
Old 03-10-2003, 02:44 PM   #6
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
If I'm reading this right, you're having custom pistons made to produce a 9:1 static ratio, and you're concerned about the frame propagation within the chamber, i.e. efficiency vs. detonation? If money were no object, I'd tell the piston manufacturer I wanted a copy of the crown of the STi pistons, yielding a 9:1 cr, then run alcohol injection. Done.
n2xlr8n is offline   Reply With Quote
Old 03-10-2003, 02:54 PM   #7
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Well, you're close. I just purchased a JDM WRX engine for pretty cheap (with 9:1 CR from the factory) and I was curious about efficiency vs. det. in that particular engine. I was just trying to get a gauge of where I would end up while tuning (and hoping the piston was designed like the STI one). The engine is being used for temporary pleasure while I build up a custom 9:1 engine that's sleeved, closed deck, forged pistons/rods, yadda yadda.
Old 03-10-2003, 03:04 PM   #8
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Well, I hate pat answers, but it would depend heavily on whether or not the JDM WRX combustion chambers are the same as the ones you plan to use on the nastie. Short answer: run alcohol and love it.
Old 03-10-2003, 05:33 PM   #9
Delicious Tuning
Member#: 1990
Hey wackie,
We have the same engine going into one of our cars. Though like you said we are not sure about the internal work of the engine, wether it is similiar to that of the USDM WRX or that of the JDM STi. Though We would really love it if it was similiar to that of the STi.
Delicious Tuning is offline   Reply With Quote
Old 03-10-2003, 05:37 PM   #10
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
Yeah, Adam told me you were getting one of those. You've actually got my car (and my new flywheel) sitting at your shop. My engine should be there this week. If you want to find out what the engine looks like inside, feel free. Just don't charge me for the labor.
Old 03-10-2003, 06:39 PM   #11
Delicious Tuning
Member#: 1990
Well I don't think we will be taking it apart. But as soon as I get mine in I will be tuning it with the EcuTek. Yeah AVCS... So if you were thinking of tuning it even though you are going to be upgrading to another block I will probably have a fairly good map for it.
Bill
2004 WRX hybrid - 2.5L 9:1 CR GT35R Topspeed tuned CoolRex Proven Power Bragging 61 02-16-2011 09:23 PM
Break-in tune: 2.5L 9:1 CR EJ257 + GT35R = 430whp @ 15-16psi jays05 Proven Power Bragging 96 03-05-2010 08:36 AM
Custom Arias 2.65L 9:1 compression Pistons Texy32 Engine/Power/Exhaust 1 03-19-2008 10:20 PM
What CR pistons needed to drop Hybrid CR Twiztidunreal Built Motor Discussion 8 03-16-2008 02:48 PM
Very little lag with 9:1 CR jdm EJ205 Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 07-27-2005 08:51 AM
