Old 03-07-2003, 08:43 PM   #1
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Default Midpipe/exhaust question
I'm thinking of getting a new 2.25" midpipe welded up to my Blitz Nurspec.
I have a 2.25" mid right now already, with no resonator, and an Apex'i silencer in the Nurspec to quiet things down. The loudness of the Blitz doesn't bother me, its the damn excessively loud droning in the cabin that bothers me. The silencer takes away the droning but makes the sound outside well, sound like my damn car is farting. I've had people comment on my car asking just what exactly is wrong cause it sounds so bad.
Anyway, what I'm wondering is would a secondary muffler welded into the midpipe would do a better job of cutting down the droning? Decreasing the overall sound level I reckon would happen as well but I can live with it. Or would a resonator do the job?
Secondly, does placement of the resonator or muffler matter in the midpipe?
Thirdly, is there even space under there for a secondary muffler? I haven't looked under there in a while and can't remember if there is.
Keiho is offline   Reply With Quote
Old 03-08-2003, 12:10 AM   #2
Andrew
Member#: 1170
2005 STi
put in borla headers instead. it will totally transform the sound. this was my car before borla. http://members.aol.com/specopsrb6/scoobyblitz.wav
post borla.
http://members.aol.com/specopsrb6/borlablitz.wav
that was my car with stromung 2.25 midpipe, nurspec, and borla headers. from what i remember, there was no droning. but i cant remember too well, it was a couple years ago that i had that setup.
Andrew is offline   Reply With Quote
Old 03-08-2003, 01:51 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ya, if sound is what you want get the borlas.
Old 03-08-2003, 07:18 AM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I have an automatic I should mention, so when I'm cruising around town without the silencer more often than not the rpm is at the range where it drones the loudest.
I want to get rid of the droning with the minimal cost without using the silencer.
If I'ma get headers I'm getting custom 4-1 equal length a la MRT header made up.
Old 03-08-2003, 03:47 PM   #5
joefocker20
Member#: 13745
2015 STI
I concur, put some Borlas on there..
joefocker20 is offline   Reply With Quote
Old 03-08-2003, 08:05 PM   #6
wistful
Member#: 745
2004 STi
Java Black Pearl
I had custom 4-1 MRt-esque headers w/ a 2.5" on top a Blitz can and goddddd darn it sounded good. Still the best sounding RS I've ever heard. Till I lost hearing sensitivity from how freaking loud it is.
Now, I'm running TWE headers, and 2.25" Brullen quiet. Still decently loud and drone but not nearly as bad. I can drive comfortably and converse on the highway now. I think its the hi-flo cat that makes it drone on mine.
Don
wistful is offline   Reply With Quote
Old 03-08-2003, 08:07 PM   #7
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
How are the TWE headers Wistful?
So no one has any idea if a secondary muffler would help cut down or eliminate the droning?
Old 03-08-2003, 10:14 PM   #8
Supapooh
Member#: 4461
02 2.slow
Currently I have Borla Headers, Random Tec Cat, custom 2.25 midpipe w/ 18" resonator, and a blitz nur spec rear section.
Before I installed the hi flow cat, I had the same setup minus the custom mid pipe I was running a stromun 2.25. After installing the cat it was way too loud. Un bearable and definently would had gotten me the attention I don't need. So I went and had a 2.25 pipe made with a resonator. The sound is ok... the midpipe is made out of the everyday shop metal so it had a tinny sound to it. But the resonator all but elimated the drone I had on the highway.... I guess long story short resonator killed the drone.
Supapooh is offline   Reply With Quote
Old 03-08-2003, 10:40 PM   #9
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
So its safe to say a reasonably large resonator would do the job of cutting down the drone then? Good good.
Old 03-08-2003, 11:02 PM   #10
Andrew
Member#: 1170
2005 STi
keiho, my sound clips are from a 4EAT as well.
Old 03-08-2003, 11:41 PM   #11
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I can't get your wav files to play though.
Old 03-09-2003, 12:23 AM   #12
Andrew
Member#: 1170
2005 STi
have you tried using winamp for the sound files?
Old 03-09-2003, 12:30 AM   #13
watcher in the sky
Member#: 3513
1997 Legacy Outback
off topic, but .. haha.. i like that location you are at andrew!
watcher in the sky is offline   Reply With Quote
Old 03-09-2003, 02:58 AM   #14
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I've tried everything, winamp, winmedia and even IE...nothing works. Says there's an error downloading the codec or something...codec error anyway.
Well, does your exhaust still drone or did the Borlas cancel it out?
Old 03-09-2003, 03:53 AM   #15
Andrew
Member#: 1170
2005 STi
i remember before goign turbo, i sold the borlas and went back to stock headers/2.25 midpipe/blitz and i was disgusted by the sound. it droned like crazy and i could rarely find an rpm that i liked to cruise in. i found it hard to believe that i actually liked the sound before. from what i remember, there was less droning if any. it should replace that ugly drone with a strong flat 4 rumble.
if you can, maybe find someone local with some borlas, and ask if you can just test fit them for a couple minutes.
on a side note, ive sent the link of the wav's to other people and it works for them ill try to change the wavs somehow and upload them in a bit. edit: im uploading the files to my geocities account. they came out to be 2.4mb wav's but hopefully itll work for you. its not cruising sound clips, sorry its just startup with some revs.
Old 03-09-2003, 04:07 AM   #16
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
I think a resonator would be more economical though. That's mainly why I'm wondering if a resonator would work.
Unless I can find someone selling their Borla's for like...a hundred dollars. Canadian.
Old 03-09-2003, 05:11 AM   #17
Andrew
Member#: 1170
2005 STi
Old 03-10-2003, 03:40 AM   #18
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Wav files work now thanks.
Downpipe to midpipe exhaust leak WaRioX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-07-2009 03:23 PM
WRB 3'' Catless midpipe/exhaust TheSomethingorother Private 'Wanted' Classifieds 0 09-03-2008 12:20 AM
Serious Midpipe Exhaust Rubbing 05shagginwagon Newbies & FAQs 3 07-11-2008 03:17 PM
wtb stock sti 3inch midpipe exhaust DapRex Private 'Wanted' Classifieds 2 04-06-2006 05:30 PM
custom fab-ed midpipe/exhaust for a 1.8... RaceCarRiot Normally Aspirated Powertrain 6 06-15-2001 08:20 PM
