![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 453
Vehicle:2013 VT |
I've been pondering between the durability and reliability of the Sti Ver V struts vs the adjustibility and height lowering friendliness of the KYB-AGX struts. My question is that are Ver V struts not good to combine with lowering springs? I get that impression from some other ppl on various diff suspension threads. Should they be only used with springs that do not lower the car very much? I'd ideally like to get Sti struts with springs that will lower my car about an inch, but no more. Any thoughts on this idea? Thanks
Ed
#2 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
dunno...
i don't think any one has had a really BAD expirance.... yet... someone has discovered that his struts were leaking.. weather that was realated to the springs/ride height is anybody's guess the v.5 struts seem to be well matched to a spring set aprox 25% stiffer than the 160/160 stock springs also they are REALLY cheep... |
#3 |
Member#: 6703
Vehicle:1999 rs/wrx hybrid silver |
hey howsit going . wel i got the ver 5 struts and a 1.75 drop for about 4 or 5 months now . and i havent had one problem . i have the stock rims and tires and it neverrubed either . i was told that i should be fine by rally spec, and they where right!!! .. plus it looks great
#4 |
Member#: 391
Vehicle:2004 STi Blue/Gold 2000 RS BRP |
Ver5 struts were meant to be with:
Ver5 or Ver6 or P1 springs ![]() |
#5 | |
Member#: 177
NWIC
which is ~ 20-25% stiffer than a stock RS spring |
#6 |
Member#: 1997
Vehicle:2006 Acura TL 6spd STMGM6 alumni |
FWIW the STi struts work better than the KYB AGX in lowered applications. The strut shaft is shorter on the STi strut. AGX strut have known problems past 1.25" or so. So If you're going for a big drop, dont buy AGX.
| Thread Tools | |
| Display Modes | |
| Quick Q: 2.5RS Rear Strut lower spring perch lower than WRX rear strut spring perch? | bwco | Brakes, Steering & Suspension | 0 | 06-29-2004 06:24 PM |
| FT: Stock Springs/Struts plus $$ for Any stock struts / lower springs besides eibach | relirex | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 03-12-2004 01:02 PM |
| STi Ver 5 struts & springs | BadDogNoBiscuits | Brakes, Steering & Suspension | 4 | 03-12-2002 03:26 AM |
| STI ver. 5 struts/TEIN soft springs | Imprezz25rs | Brakes, Steering & Suspension | 5 | 02-09-2001 07:16 AM |
| Sti Ver 5 Struts and H&R springs | RS_NW | Brakes, Steering & Suspension | 0 | 11-21-2000 10:45 AM |
