Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 03-08-2003, 06:27 PM   #1
Member#: 12644
2015 Audi S4
Monsoon Gray Metallic
Default Blown Tranny, or Diff, or what ??
Today, i am driving on the parkway and i shift 2nd on the on ramp and everything locks up and grinding sounds are comihng from the tranny. i pull over and can't get it into 1st and 2nd gear, and when i put it in neutral and let the clutch out it is grabbing like its in a gear halfway. maybe somethings bent or broken, so finally i get it into 3rd and get it to my friends house while its making a slight noise from the gearbox of something down there. after that it totally freezes and i get it into neutral again and its basically fully neutral with a slight griding noise, but so pull like it is in gear as it was be4 doing. so i flatbedded it to a subaru dealer and dropped it there and am going to go in monday morning to explain my problem. any takers on possiblities of what it could be. could my tranny have just all of a sudden blown, could i have bent something so it wont go into any gears fully or at all, could i have blwn the differential or something? whatever it is i have 29k miles on my car its an 02 impreza 2.5 rs. it should obviously be warrantied. i do have intake and a headerback exhaust on my car, but whatever they work on cars that have work there all the time, but ive never had it in for transmission work. just let me know what u guys think. THANX
jdsimpreza is offline   Reply With Quote
Old 03-08-2003, 06:55 PM   #2
Member#: 922
16 WRX (white)
04 FXT (red)
Sounds like second is stripped. Hope your dealership is as leinient as you think with the mods... mine would have complained and they're considered fairly leinient. *shrug*
Old 03-09-2003, 02:02 AM   #3
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I am going to guess a bent shift fork due to hard shifting. It is keeping a gear slightly engaged while you are trying to select a different one.
It is only a guess.
Old 03-10-2003, 07:06 PM   #4
Member#: 30603
sounds like what happened to my car when i did the gearbox. there were no teeth lefted on 1 of the gears.
Aussie_STI555 is offline   Reply With Quote
Old 03-11-2003, 01:57 AM   #5
Member#: 4603
1994 Mioterr R pack
not diff...sounds like shift work or gear shrapnel
MattSEG is offline   Reply With Quote
Old 03-11-2003, 03:16 PM   #6
Member#: 21414
02 wrx
if it is stuck in a gear and kind of hard to get out but you wiggle it a little side to side and down at the same time it's a shift fork but more than like a shift fork they are junk in these cars the whole damn tranny is.
2002whitewrx is offline   Reply With Quote
02 wrx blown tranny and rear diff kingstarlet Drivetrain 17 04-01-2008 08:42 AM
Blown Tranny or Diff? PLEASE HELP!!! VladiWrX Transmission (AT/MT) & Driveline 16 02-06-2008 08:16 PM
blown tranny, bad synchros, or bad clutch? project_legacy Transmission (AT/MT) & Driveline 9 03-25-2007 12:45 AM
Is this my clutch, tranny, diff, or what? Ender the Xenocide Transmission (AT/MT) & Driveline 2 01-18-2006 07:02 PM
changing tranny and diff fluid what weight is best gsteclipse33 Transmission (AT/MT) & Driveline 8 02-17-2005 09:39 AM
