Old 04-18-2001, 04:06 PM   #1
Jessie James
Member#: 2072
Post Is anyone running RE730's at 225/50/16 on stock MY00 rims?
Like it says. Do they rub, or otherwise have problems. I am especially interested in hearing from those folks with lowered cars. I'm running the Tein medium springs and stock (I know, don't remind me) struts.
Thanks!
James
Jessie James is offline   Reply With Quote
Old 04-18-2001, 10:34 PM   #2
DaveK
Member#: 2338
1988 323 GTX
black
Post
Not sure if this will help, but here goes.
I saw a set of 205/55/16 (RE730s) and there was a very small amount of clearance between the tire and the strut (KYB AGX). So I'd say don't try it, but then again, with the shorter sidewall it just might fit (although I'd doubt it).
DaveK is offline   Reply With Quote
Old 04-19-2001, 07:03 AM   #3
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Post
I'm running Pirelli p7000 SS in 225/50 16's on stock rims with KYB AGX Struts and Eibach coilovers -- no rubbing. I don't think I'd feel comfortable putting anyone in the back seat though.
-Kurt.
Darshu is offline   Reply With Quote
Old 04-19-2001, 08:09 AM   #4
subrew2
Member#: 2883
2004 STi
Silver/Gold
Post
I'm running both a set of Yoko A-008RS2 and a set of Kumho V700s in 225/50-16 size on stock '98 and '99 alloys respectively.
I must run a 3/16" spacer on the back to avoid rubbing the strut. Also, before installed the KYB's, they rubbed on the fender lip molding. Not much rubbing now, with the KYB turned up a bit.
Chris Hartman www.subrew.com
subrew2 is offline   Reply With Quote
Old 04-19-2001, 10:58 PM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I imagine the wider 225/50x16 will not fit.
The RE730 in 205/55x16 barely fit my car in the rear with the stock struts or AGX struts with Tein Stech springs - but it fit.
It missed the strut by 1/8" on the inside, and with the Tein Springs I had a bare hint of rub on the rubber strip lining the fender while it stayed off the strut. I had (-)1 degree camber in the rear.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 04-20-2001, 05:24 AM   #6
Canbaru
Member#: 3475
2004 WRX Wagon
Question
Chris,
Where do we get the right spacers? Can we just walk into Pepboys and take off the shelf - or do we need to specify hub bore, bolt pattern - and is there a certain quality recommended (alum vs. steel, etc.)
thanks,
Tim
Canbaru is offline   Reply With Quote
Old 04-20-2001, 08:09 AM   #7
subrew2
Member#: 2883
2004 STi
Silver/Gold
Post
I actually made my own spacers. Used some scrap graphite impregnated high density polyethelene we had in R&D. It has a higher compresive strength then aluminum, as well as a good resistance to heat. It is also light, and easy to manufacturer with typical home tools.
I'm going to make a set of 1/8" spacers this weekend to see if the Kumhos will rub the struts or not.
c'
225-50-16 on stock WRX rims WRC51 Tire & Wheel 49 09-05-2009 02:05 AM
Anyone regret going to 225/50-16 on stock wheels? edh Tire & Wheel 14 01-20-2005 09:08 PM
What is the right tire pressure for 225/50/16 on stock rims ? flyingace Tire & Wheel 6 05-24-2004 10:48 PM
225/50-16 or 205/50-16 on stock WRX rims? carlm Brakes, Steering & Suspension 6 03-17-2003 06:34 PM
does anyone with 225/50/16 and stock MY00 suspension have rubbing (searched) 10th Warrior Brakes, Steering & Suspension 2 06-23-2001 03:27 PM
