Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 03-08-2003, 10:44 PM   #1
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
Default anyone comfortable with adjusting the tie rod?
hey
got back from an alingment...they did a good job.
just that the wheel sits off centered...
i go to a special place too far...and i can't make the drive anytime soon.
is anyone in bay area comfortable with adjusting the tie rods to make the wheel centered? without adjusting the toe of course
i would like to learn myself...so if anyone can spare 30 to an hour of their afternoon...please PM, e-mail or post here
i am in mid-pennisula (burlingame)
thanks
alex
secretaznboy is offline   Reply With Quote
Old 03-08-2003, 10:56 PM   #2
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
And then you can teach me too. I have a relevant question to ask as well (or two):
Do you have to use any special tools on the tie rods to prevent from messing up the faces of the bolts?
Also, about how much does one thread on the tie rod adjust toe?
Steppin Razor is offline   Reply With Quote
Old 03-09-2003, 12:09 AM   #3
leoneo01
Member#: 13691
'01 2.5 RS
BDP
I use two adjustable wrenches and a measuring tape. First loosen the lock nut. To adjust, turn the tie rod. I try to get 0 toe, so I measure the distance between the wheels from the front of the tire and compare it to the distance between the wheels from the rear of the tire, trying my best to make them equal.
leoneo01 is offline   Reply With Quote
Old 03-09-2003, 12:19 AM   #4
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
razor...the answer to ur question has been answered in a post.
search for tie rod...and read that thread.
leoneo01...my toe is already at 0 right now.
however...i need to adjust the tie rods so that the steering is cenetered.
to my understanding...alli need to do it when i turn one end in, and then the other end out at the same distance.
this will keep the toe from getting out of alingment.
eoneo01
i can drive to union city...do u think u can teach me how to do it?
thanks
alex
Old 03-09-2003, 05:41 PM   #5
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
bump
Old 03-10-2003, 03:17 PM   #6
leoneo01
Member#: 13691
'01 2.5 RS
BDP
pm'd you
Help. Can't adjust toe - tie rod stuck leecea Brakes, Steering & Suspension 4 05-18-2009 09:23 AM
Any tips on removing the tie rod shaft from the knuckle? PJC1909 Brakes, Steering & Suspension 4 06-16-2007 01:46 PM
oops: anyone have a right inner tie rod nhsilversti New England Impreza Club Forum -- NESIC 1 10-22-2004 12:06 PM
Cusco Front and Rear Swaybars Installed - Getting some rubbing on the Tie-Rod turbinepwr Brakes, Steering & Suspension 0 08-01-2004 11:15 PM
Message Board Statistics All times are GMT -4. The time now is 01:35 PM.
