Old 03-09-2003, 02:09 AM   #1
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
Question Where can I get spark plug wires?
Who manufactures spark plug wires for 2000 Impreza RS and where in the world can I get them?
I don't want to spend $53 or more and have to special order an OEM replacement from Auto parts stores here so I am looking for aftermarket.
Thanks
Jim
Respected Performance
SubieFL is offline   Reply With Quote
Old 03-09-2003, 04:01 AM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Magnecore, Sparkco, NGK...etc...
I'd go with Magnecore or NGKs.
Keiho is offline   Reply With Quote
Old 03-09-2003, 06:42 PM   #3
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
Thanks. Where can I buy them?
Old 03-10-2003, 12:55 PM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Make your own, its cheaper. Check out scoobymods.com for a couple of options (I did the custom MSD write up). Anything is better than stock, so really it doesn't matter which brand you go with. Magnecores are a high resistance wire (I think the NGKs are also) which means they should be a quick swap. MSDs, Taylors, etc can be bought in 2 versions... high and low resistance. Low resistance wires will get more spark to the plug (in the same time interval) but the gap must be increased (rather dramatically) to keep them firing correctly (your moving the current at low resistance but the overall resistance of the system must remain rel constant so you increase the effective res by increasing the plug gap... make sense?). Stay away from Nology Hotwires, Direct Hits, etc as they are somewhat gimicky and way expensive for what you get... Any spark plug or wire that claims hp increases is b/s.
Old 03-10-2003, 01:03 PM   #5
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
Magnecor can be bought from cyberauto.com, or direct from Magnecor.
BlueTDimly is offline   Reply With Quote
Old 03-10-2003, 02:09 PM   #6
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
OK. It makes sense. Thank you.
Old 03-13-2003, 01:24 AM   #7
nixx
Member#: 7581
2001 Impreza 2.5RS
I heard the Sparcos are inferior to other plugwire brands. I forgot what was actually said about them but I know to avoid them.
nixx is offline   Reply With Quote
Old 03-13-2003, 09:59 AM   #8
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
I just ordered a set of the Magnecors. Anyone know if they have a different resistance so that I may need to gap the plugs different than stock?
Thanks
Jim
Respected Peformance
Old 03-13-2003, 10:40 AM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Nope, stock gap should be fine with the Magnacores.
alright.. so where can i get a trailer wiring harness? sky44 General Community 5 09-06-2008 10:57 PM
does any know where i can buy spark plug wire for ver4 sti myurbanracer Pre-2002 Factory Turbo Powertrain 11 02-25-2008 01:21 AM
Where did you get your Plug wires? spdracr00 Legacy Forum 1 02-19-2005 03:00 PM
where can i get accessport plug for 02 skimmilk68 Newbies & FAQs 1 07-12-2004 12:07 AM
Where can I get harness, or wiring done BigPawr Subaru Conversions 2 03-01-2004 06:59 PM
