Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 03-09-2003, 02:02 PM   #1
deks
Member#: 13803
Unhappy oil reading before service maintenance
i'll be having my regular service maintenance this next week. i noticed when i checked my oil reading today it was on "low". is this normal? does this mean my car burns oil? i don't see any leaks. any ideas?
thanks.
deks is offline   Reply With Quote
Old 03-09-2003, 02:07 PM   #2
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Default Re: oil reading before service maintenance
thanks.
ya, that's definately NOT a good sign.
for a car that new there should be no leaks big enough to give you that 'low' light.
get it in the shop asap...
for now, i suggest you check and re-check your oil level under the hood.
be sure you have enough oil... oil is the life blood of your car and your turbo... good luck!
SD
suby_dude is offline   Reply With Quote
Old 03-09-2003, 02:10 PM   #3
deks
Member#: 13803
Default re
thanks. what i meant was oil level reading not the light. the light doesn't lit... yet
Old 03-10-2003, 03:51 PM   #4
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
It's very common for new BMW engines to use a quart or two of oil between changes. Mini owners have reported the same thing. OTH, my Subaru has never used any that I can tell by looking at the dipstick.
One of the many reasons I no longer own a BMW...
Check under the car for obvius signs of oil leaking out, taking off the plastic shield right behind the bumper will allow you to see the front of the motor, my driver's side seal at the front of the car looks a little wet but Santa Cruz Subaru said it was nothing to worry about and like I said, the car has not used any perceptible amount of oil.
If the bottom of the motor is dry, you may be burning some oil or perhaps you didn't get it completely full last time you changed it?
Good luck, and you should be just fine if you keep an extra quart in the car and check it often.
Stanley is offline   Reply With Quote
Old 03-10-2003, 04:19 PM   #5
deks
Member#: 13803
ok. i'll be doing that checks later. i'm carrying 6 quarts of oil in my trunk right now just to be sure. well since i'm due for a service this week
thanks!
Midwest Services - Oil Changes, 30k Services, 60k Services, Dyno Rentals!! P&L Motorsports Inc. MWSOC Vendor Classifieds 28 07-02-2007 06:17 PM
Share your service/maintenance log forms! grindMARC Service & Maintenance 8 03-11-2004 09:41 PM
Read Before Changing Your Oil hyperion STi Forum Archive 16 09-01-2003 11:55 AM
Service Maintenance Kato Alaskan Impreza Club Forum -- AKIC 6 05-28-2003 06:03 PM
Service Maintenance Pricing epicurux Bay Area Impreza Club Forum -- BAIC 12 04-23-2002 09:13 PM
