Old 03-09-2003, 08:44 PM   #1
fajenRS
Member#: 21896
2000 Impreza 2.5rs
Blue Ridge Pearl
Question nitrous
The local track is opening in a couple weeks, and I was thinking about installing a nitrous kit and testing it out on opening day. Problem is, I'm not so sure of what kit to purchase. I'd like to go with a wet system after hearing of possible problems that could happen with a dry system. I've looked at the Nitrous Oxide System website but they don't have a wet system for my car (2000 Impreza 2.5rs) but they do for the WRX. Would the WRX kit work on my car? Thats probably a stupid question, but I thought I'd ask anyway. If the WRX kit doesn't work then what are you guys using for wet nitrous systems and how have your experiences been with them. Any info would be greatly appreciated. (no pressure but I kinda need to know quickly. . . . . .track opens soon and I need time to order the kit and install)
fajenRS is offline   Reply With Quote
Old 03-09-2003, 10:37 PM   #2
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
zex was coming out with a universal wet kit, dunno if its out yet though. i think NX has a universal wet kit too. i've been using a zex dry kit for like a year with no problems.
jasona is offline   Reply With Quote
Old 03-10-2003, 01:40 AM   #3
That Guy
Member#: 23212
2002 Impreza RS
jasona, how do you like your kit? Hard to install? Hard to use or get used to using?
That Guy is offline   Reply With Quote
Old 03-10-2003, 01:47 AM   #4
dcoty
Member#: 3149
01 V7 GC/R32 sky
I had a zex dry kit. Really easy to install (a bit of wor to make it look clean though),and its easy to get used to. You might need a new clutch, i never felt my 50 shot until i had a new clutch put in, it wuld slip all the time, never grabbed! Go with ACT.
Dan
PS: The switch for the kit is cool, but easy to spot by cops if you ever get stopped.
Get a bottle warmer 100% as well as pressure gauge, very nice things to have, otherwise you are pretty much blind to your bottle pressures when they fill it for you and the warmer gives you better sprays, even on low bottles.
dcoty is offline   Reply With Quote
Old 03-10-2003, 01:50 AM   #5
jasona
Member#: 11786
2014 OB 2.5i 6MT
freakin easy to install. if you know where the TPS wire and FPR are, you can do it in 20-30 minutes. sometimes ive done a quick install in a friends car so they could race something, in exchange for a full bottle after theyre done. using it is also easy. i put the switch down by the shifter, and when i leave the line, as soon as i'm completely off the clutch i flip it, usually right in time to grab the shifter and go to 2nd. its almost 2nd nature by now.
edit: yes, you will probably need a new clutch too. i bought a clutchnet one, i recommend not getting one of those. it holds the nitrous once its fully engaged, but if you try to give heavy throttle before its engaged (even without nitrous) it will slip like crazy. i havent been able to get better than a 2.3 60ft since i got it, since all i can really do is just roll off the line like i would from a stop sign then gun it after i'm off the clutch. i used to get 2.1-2.0 60ft's on the stock clutch.
Old 03-10-2003, 12:46 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Get a Nitrous Express "Other Sport Compact" wet kit. Excelent quality and a great wet kit
Do a search for it on here.
Eric SS is offline   Reply With Quote
Old 03-10-2003, 01:05 PM   #7
jasona
Member#: 11786
2014 OB 2.5i 6MT
^ thats the one i was talking about. if i had it to do again, that's the one i would have bought.
FS: Nitrous Express Import EFI Stage 1 Nitrous Kit 20923-10 Brand New highperfoutlet Private 'For Sale' Classifieds 5 06-20-2006 12:40 AM
WTB: Nitrous kit, and cry02 or nitrous ic chillers unloco187 TXIC Private Classifieds 6 02-05-2006 11:43 PM
do our cars like nitrous? and is anyone running with nitrous vandejr Newbies & FAQs 28 11-01-2005 09:58 PM
Anyone with nitrous or looking to get nitrous? cvcsmkr Normally Aspirated Powertrain 36 07-12-2003 07:14 PM
ET and trap mph difference, nitrous vs. no nitrous? annointed Proven Power Bragging 45 08-07-2002 11:16 AM
