Old 04-24-2001, 10:45 AM   #1
newrxnj
Member#: 4322
1998 OBS
Angry Help! I fogged my paint while debadging...
Help me please! I made a small spot (the size of a quarter) of fogged paint while debadging my WRX. Otherwise it went very well.
Any tips on taking it away?
Thanks,
Dan
newrxnj is offline   Reply With Quote
Old 04-24-2001, 11:00 AM   #2
STi_22B
Member#: 6040
Unhappy
OUCH!! well take it to a paint shop they can touch it up for about $20...i had a key scretch a while ago. i took down to a paint shop they touched it up for $25..looks just like normal....
STi_22B is offline   Reply With Quote
Old 04-24-2001, 03:35 PM   #3
Imprezed_Driver
Member#: 3672
Post
Try a small amount of rubbing compound, then use some McGuires cleaner wax... I had a small spot like that behind the S. This method worked for me.
Imprezed_Driver is offline   Reply With Quote
Old 04-25-2001, 01:44 PM   #4
eastbaysubaru
Member#: 4110
04 FXT
Post
What do you mean by fogged? I was thinking about debadging my girlfriend's RS and was worried about the paint. I'm just worried about stuff exactly like this.
-Brian
eastbaysubaru is offline   Reply With Quote
Old 04-25-2001, 03:20 PM   #5
mack109
Member#: 3713
Post
Was the fogging from the heat or the solvent used to clean up? Use the minimum amount of heat from a heat gun or hair dryer necessary to soften the adhesive, then pass very fine dental floss behind the badge/letters and they come off easily. I thought that clean up with WD40 sounded pretty weird, but it doesn't affect the paint and the goo eventually comes off with a bit of rubbing. Finish up with car wax/polish. Looks like those letters were never there. If your paint is just fogged it should buff out.
mack109 is offline   Reply With Quote
Old 04-25-2001, 05:34 PM   #6
newrxnj
Member#: 4322
1998 OBS
Post
It was from too much rubbing... The first S took a little to get the hang of it. The rest was easy. After rubbing with GooGone to get rid of the little bits, I noticed some fogging. Again, only a tiny bit.
I just wanted good advice before I tried to fix it.
Old 04-25-2001, 05:41 PM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
detail clay and detail spray....
if you havent tried it.. do it...
you can find some here: http://www.griotsgarage.com
that's the clay and spray i recommend and use on my RS...
what it does is remove all solvents, dirt etc from the paint... even yellow paint over spray... hehehehe... not that i'd know...
j. www.subiegal.com
Old 04-25-2001, 06:52 PM   #8
markoe78
Member#: 5391
Post
just get a good wax and hand rub it out i use to work at a recon shop that should work realy good the fogy spot is from puting hair line scraches in the clear cote you should be fine see ya
markoe78 is offline   Reply With Quote
Help! I broke my #&[email protected] fog light! ursine Electrical & Lighting 7 01-14-2004 02:09 PM
Who can help me wire my Fogs? (Hella 500's) Davenow New England Impreza Club Forum -- NESIC 28 12-06-2003 01:20 PM
Does someone wanna help me with my car while I'm in town? PLEEEEZ!! GooseMan New England Impreza Club Forum -- NESIC 8 03-27-2003 01:40 PM
Got gasoline on my paint! Help!!! djerickd Car Care & Detailing 6 08-13-2001 02:33 PM
Help! Is my paint ruined? MagicMT Car Care & Detailing 23 05-29-2001 07:15 PM
