Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-09-2003, 09:26 PM   #1
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
Unhappy Overheat problems
Here's the deal,
I'm driving around town and the water temp (on factory gauge in the cluster) goes WAY high. Like red line high. In order lower down the temp, I tried turning the heater on with temp set to the warmest position. All this made things even worst ! I turned the dial back to the coolest and even if the water temp stayed above normal, it seemed to help to cool things off.
- Coolant level is O.K.
- Outside temperature was 1 degre F...
Can anyone help ?
This was my first drive after installing a VF30 (still stock engine management and no outside boost controler). I was wondering if maybe the lower coolant hose on the turbo (the one that loops over the turbo bracket) might have been pushed too far and is now kinked, hence slowing the coolant flow.
Any imput would be appreciated.
Thanks
Ti-REX is offline   Reply With Quote
Old 03-09-2003, 09:29 PM   #2
subarud
Gone.. But not forgotten
Member#: 9863
02 WRX Blue & Fast
91 S10 Red & Abused
Probably gotta burp the system, seems like you have some air in your hoses after installing the turbo.
~Evan
subarud is offline   Reply With Quote
Old 03-10-2003, 11:48 AM   #3
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
Cool
I must admit that sometimes, the search button is not often used... Mea culpa !
Burped the system and everything is like new !
Thanks
Overheat problem WhiteH2O Service & Maintenance 4 03-16-2007 03:04 PM
Help car wants to overheat at idle seven881 Normally Aspirated Powertrain 5 03-16-2003 09:58 PM
help overheat red of the sun Service & Maintenance 16 12-28-2002 11:25 AM
('93-'01) Engine Overheat, CE light problem Piusma Impreza Forum 11 06-04-2001 05:35 PM
Engine Overheat CRAZY KEN Normally Aspirated Powertrain 7 04-30-2001 07:04 AM
