Old 03-16-2001, 08:32 PM   #1
dch
Member#: 1057
2004 WRX STi
Very Yellow
Post Rotor Size vs. Wheel Size
In looking around at various brake packages, I've seen that the bigger rotors require bigger wheels. This makes sense, but it begs a question:
What do people with big-arse brakes on 17" wheels do when they want to slap on some 15" wheels and go play in the dirt? Change brakes too? ugh! Either that or just stick with the smaller brakes I suppose. Am I missing something?
(I'm looking for the largest brakes possible for 16" wheels and want to know if I'm going to screw myself out of 15" snow tires in doing so)
-Doug
[This message has been edited by dch (edited March 16, 2001).]
dch is offline   Reply With Quote
Old 03-16-2001, 08:39 PM   #2
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Post
Sure, why not? I haven't actually done it, but in the mods section it looks like changing the rotors at least isn't that much of a problem... you're already halfway there or more by taking off the big wheel anyways.
Of course, if you have bigger calipers or something that won't fit the smaller rotor, then you'd have to swap out the whole assembly and rebleed the brakes and stuff I guess.
I think the STi 4-pot big front brake kit is about the biggest you can get on the 16" rims. My friend has a set on the stock MY00 rims and they look real sweet and fill outt he wheel very nicely.
iodine23 is offline   Reply With Quote
Old 03-16-2001, 09:28 PM   #3
dch
Member#: 1057
2004 WRX STi
Very Yellow
Post
Correct me if I'm wrong (hey- it's been known to happen), but the calipers are tied to the axle, right? For a rotor with diameter X, the caliper sits at the outer circumference (the radius from the center, roughly speaking). So if you yank the rotor and slap in one that's 2" shorter (diameter-wise), you'd have to adjust the caliper position down about 1". Is there such a thing as an adjustable caliper mount? I'd sure hate to have one adjust itself on me whilst turning in... I've never paid attention to how that all ties together before. I suppose if the caliper is designed to ride on a certain sized arc, a radically smaller rotor might just plain not fit right even if you could adjust it. Might be worth a trip to my garage...
-Doug
Old 03-17-2001, 09:07 AM   #4
dch
Member#: 1057
2004 WRX STi
Very Yellow
Post
Jebus! There's a ton of info on this board about brakes! From what I can discern, Raceline RL7's in a 15" size will fit the STi 298mm brakes (most 16" wheels will fit too). Bigger means swapping brakes (calipers and all) if you want to use smaller wheels. So the answer is you can make it work within certain restrictions and cash flow categories.
Guess I should have spent the 6 hours searching before I posted, eh?
-Doug
tire size vs rim size 06STi Tire & Wheel 4 08-14-2007 09:56 PM
Tire Size vs. Wheel Width njskatchmo Tire & Wheel 15 07-31-2006 09:54 PM
Tire vs Wheel Size Virusx86 Tire & Wheel 9 03-26-2006 05:59 PM
JDM v7 wheel vs GC8 vs Tire size??? OB2 Tire & Wheel 5 03-03-2006 12:29 AM
Turbo Gurus - A/R vs. Trim vs. Wheel size?? Gixxerjb Normally Aspirated with bolt-on Forced Induction Powertrain 2 09-20-2004 11:05 AM
