Old 03-11-2003, 10:15 AM   #1
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
Default head bolt help needed
ok, so I'm following the directions in the book that I have (2.5 legacy book) and has steps to torque the bolts. The last step I'm on is to torque to 25 ft-lbs. ok, no prob. But the next is to torque to 132 in-lbs. Ok I thought, I'll do a conversion. and I got 11 ft-lbs. Is that right? go to 25 then loosen to 11?
Thanks in advance.
Courtney
9 is offline   Reply With Quote
Old 03-11-2003, 07:15 PM   #2
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
Default I wish I could help
Never done it before
bump
Merdock777 is offline   Reply With Quote
Old 03-12-2003, 10:10 AM   #3
9
Member#: 4074
1998 Impreza RS
D'OH!!!
bump...
Old 03-12-2003, 10:35 AM   #4
Jademonkey
Member#: 9213
2000 RS
Red
Not sure, but on my rs, as with any alunimum block, you do torque all head bolts down in sequence, then back off i.e. loosen them, then tighten them back up.
http://forums.nasioc.com/forums/show...head+AND+Bolts
scroll down and check my post on torquing the bolts. You're on the right track.
Jademonkey is offline   Reply With Quote
Old 03-12-2003, 12:16 PM   #5
9
Member#: 4074
1998 Impreza RS
Cool, Thanks. That's pretty much what my book said. Now I can't wait till I get home to put my engine back together.
blown head gasket. help needed! bnr34rb26dett Newbies & FAQs 5 08-06-2009 11:50 AM
Urgent Head Gasket Help Needed!!!!! BizzarBoxerXt Tri-State Area Forum 23 07-04-2008 09:35 AM
Head Gasket Help Needed (2002 WRX Wagon) WRX.357 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-16-2008 08:55 AM
Uppipe leak then dislodged cylinder head plug help needed MRF582 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-09-2007 08:28 PM
Head bolt info needed, plus a sad link about ARP IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-23-2003 04:32 AM
