Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-11-2003, 11:25 AM   #1
Will98RS
Member#: 15816
1998 Impreza RS
Default where to buy toggle switches?
im looking for a few different kinds of toggle switches: guarded, momentary contact, on/off, three postion etc. is there a company that makes a few different kinds that match?
thanks
will
Will98RS is offline   Reply With Quote
Old 03-11-2003, 06:37 PM   #2
StealthWagon
Member#: 30823
2004 WRX STI
Blue/Gold
Radio Shack! They have tons of switches and are much cheaper than any others I've found.
StealthWagon is offline   Reply With Quote
Old 03-12-2003, 09:18 AM   #3
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Waytek Wire. Do a Google search to find them. Great prices and nice stuff.
jack
Old 03-13-2003, 08:38 AM   #4
gravel
Member#: 11962
SILVER
try Newark Electronics - www.newark.com
They should have everything you're seeking.
gravel is offline   Reply With Quote
Old 03-13-2003, 02:28 PM   #5
NewFor2002
Member#: 30775
2002 2.5 TS
Default WRX custom switches?
Is there anywhere that has cheap switches that will pop right in to the 02 WRX? I tried subaruparts, allsubaru, etc, but they only have those custom STi switches that are like $45. The Radio Shack ones could work; they just don't fit exactly and knowing me that s***'ll look totally ghetto if I try to cut-out and put one in.
NewFor2002 is offline   Reply With Quote
Old 03-13-2003, 05:14 PM   #6
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Default Re: WRX custom switches?
Our local electronics parts supply place has several switches in lit and plain versions that fit right into the normal panel openings. This is a place called Norvac - they have an entire aisle - about 20 feet - of switches. Two other easy ways to get what you want are to go to any "U-Pull" junkyard and get some switches - most imports use the same size switch cut outs - or just get some blank switch hole covers, and mount into those covers the switches you want.
BTW - Radio Shack is overpriced and really has very few switches compared to a decent electronic parts supply house. For some other ideas try Parts Express or check out the many thousand switches at Allied.
I have 3 "extra" switches in my car - one is a rocker plus window wiper/washer switch that runs my laser jammer, one is a rear window heater switch (push/push) from an older Legacy that switches somw extra lights, and one is a normal mini toggle in a blank that runs the garage door opener. Each has their own pros and cons. But the only one that is at all noticable is the toggle - all the rest look stock.
Alan is offline   Reply With Quote
Where to buy and how to wire levelling motor switch for STi EDM lights? Orson Electrical & Lighting 22 02-02-2005 09:24 AM
where to buy hobbs pressure switches? sick1.8t Off-Topic 4 06-25-2004 01:13 AM
anyone know where to buy the stock push-in switches? vapore0n New England Impreza Club Forum -- NESIC 3 05-27-2003 09:27 PM
where to buy OEM accessory switches zacek Interior & Exterior Modification 4 11-27-2002 11:43 AM
Where to buy a pressure switch? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-26-2002 11:09 PM
