Old 03-11-2003, 12:44 PM   #1
Dealer Xing
Member#: 4673
Default What's the wheel offset for 92 L wagon?
Just wondering what the stock wheel offset is.
will 40 Offset fit and work?
Dealer Xing is offline   Reply With Quote
Old 03-11-2003, 12:58 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I believe stock wheel offset is around +50-53mm.
Did you have 14" wheels stock or 15"
I battled with wheels on my 90 for some time. I have +45mm on there right now, and still had to shave the rear fender lip slightly.
You may have more room in the fenders with a wagon though.
However....+40mm may be pushing things.
Legacy777 is offline   Reply With Quote
Old 03-11-2003, 01:12 PM   #3
Dealer Xing
Member#: 4673
i have 185/70/14 stock. Want to upgrade to 15"
It fit a 95+ legacy sedan, not sure if it fits my wagon.
Old 03-11-2003, 01:20 PM   #4
Legacy777
Member#: 4800
ehhhh.......it's going to be close......The 2nd gen legacies had more room in the fenderwell.
You could try it......no guarantees.
Old 03-11-2003, 01:21 PM   #5
Legacy777
Member#: 4800
wait.....are the enki's 15" or 16"
15 would prob work....or have a greater chance of working then 16's.
Old 03-11-2003, 01:54 PM   #6
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Provided you are adjusting the tire sizes to keep an overall equilvalent outside diameter, wheel diameter will make no difference in this case. Width of the particular wheel might affect it, though.
-Brian
KD7000 is offline   Reply With Quote
Old 03-11-2003, 02:40 PM   #7
Dealer Xing
Member#: 4673
it's 6.5" wide. And I am going to put my 205/60/15 on them.
Old 03-11-2003, 02:40 PM   #8
Legacy777
Member#: 4800
-Brian
Brian it will make a difference, for the reason you stated, wheel width usually does not stay the same between wheel sizes. If you take a 15x6 rim vs. a 16x7 rim with tires of the same overall diameter.......the 16x7 will have a greater chance to rub and give you problems.
Old 03-11-2003, 03:53 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
205 55 16 on 6.5 wide with 55 offset can rub in the front inner wall and the back spring seat under extreme conditions
205 50 16 on 6.5 wide with 55 offset will rarely rub.
205 60 15 on a 6.5 wide 15 will be somewhat soft in the sidewall, 40 offset will almost definatly rub on the outside and the wheel wells.
Old 03-11-2003, 05:21 PM   #10
sovereignmk1
Member#: 11858
1998 Silver Legacy
205 60 15 on a 6.5 wide 15 will be somewhat soft in the sidewall, b40 offset will almost definatly rub on the outside and the wheel wells.
40 = rubbing for sure!
//Mark
sovereignmk1 is offline   Reply With Quote
Old 03-11-2003, 05:50 PM   #11
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
No kidding. Please read what you wrote. It's the width that matters, not the diameter. Sure, bigger wheels tend to be wider, but that's not the point. Nor is it always the case.
--I bet you a 17"x 7" would have a better chance of fitting than a 16"x 8.5"
Why is this even debatable? It's a simple fact.
-Brian
Old 03-11-2003, 07:23 PM   #12
Legacy777
Member#: 4800
-Brian
I think we're agreeing, but saying it in different ways.
What I was trying to get at is that most wheels come in the size/width combos I mentioned. Yes there are exceptions I know.
It's not too often you find a 16x5 wheel. I was just saying if he get's a common wheel, the width will probably increase with size.
Old 03-12-2003, 11:00 PM   #13
Dealer Xing
Member#: 4673
According to the seller, these wheels with 40mm offset fit his 95+ Legacy, shouldn't those 95-98 Legacy mechanically the same as 90-94?
Old 03-12-2003, 11:07 PM   #14
ciper
Member#: 15543
90BJ Legacy LS ABS
"shouldn't those 95-98 Legacy mechanically the same as 90-94?"
Yes, either he is wrong about the offset or they are the incorrect wheels. Sounds like VW wheels if you ask me!
Besides, even if they do work do you want to create even more stress on the wheel bearings than already exists?!
Old 03-13-2003, 09:55 AM   #15
Legacy777
Member#: 4800
The bearings and wheel hub may be the same as the early gen legacies.
But the fender clearance is different. The 95-98's had more flaring....mainly in the rear, compared to the 90-94's.
Old 03-13-2003, 06:39 PM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
But its still the wrong offset, the pivot point of the wheel will have significantly more tire area towards the outside of the car compared to the inside using a 40offset.
17" Bronze Wheels with perfect offset for a WRX Wagon - What's out there? trahsub Tire & Wheel 9 01-04-2006 12:09 PM
17x8" wheels.....whats the lowest offset for sedan gpfan Tire & Wheel 5 08-19-2005 03:07 PM
2002 WRX Wagon Wheel Offset for 17" FuelCutOff Tire & Wheel 2 07-25-2003 11:12 PM
What is the ideal offset for 18x7.5 wheels? scootr Brakes, Steering & Suspension 9 04-27-2001 06:26 PM
what's the ideal offset for a 15inch rim????? joe z Technical Forum Archive 7 09-26-2000 09:29 PM
