Mid Atlantic Impreza Club
Old 03-11-2003, 02:09 PM   #1
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
Default Who has their fenders rolled and where did you get it done?
I'm expecting to have to roll my fenders next week. Who has gotten thier rolled in MD or Northern VA? Where did you get it done, how much, and what kind of horror stories do you have?
Thanks
rex n effect is offline   Reply With Quote
Old 03-11-2003, 02:27 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I got mine done at CDE Motorposts, but they are now called Ultimate Performance. I think it cost around $200, but it was done RIGHT. Heat gun to soften the paint, and the special tool that fits on the hub and actually rolls under the fender. I have absolutely no paint cracks and the fenders look great.
http://www.cdemotorsports.com/
Old 03-11-2003, 02:32 PM   #3
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
there was a guy over in suspension/tires who said that curry's cracked his paint while rolling the finders I dont have the link, but you can search for it.
elgorey is offline   Reply With Quote
Old 03-11-2003, 02:49 PM   #4
VSM EXtasy
Member#: 5220
98 SVT Contour
paint cracks, older it is its easier for it to crack. There nothing you can do about it if it does, they do their best not to let that happen. Thats why Curry's or CDE they both make you sign waviers that say their not responible if it does crack.
If your car was repainted by a body shop it has more of a chance of cracking. If i fix the camber on my car the fenders has to be rolled but i'm not taking the chance of the paint cracking.
VSM EXtasy is offline   Reply With Quote
Old 03-11-2003, 02:57 PM   #5
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
Okay, maybe this is a dumb question, but what is "fender rolling"? I have heard the term quite a bit, but I don't know what it is.
Cosmo is offline   Reply With Quote
Old 03-11-2003, 03:26 PM   #6
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
if you look under your fender, there is a lip pointing inwards. You basically fold/roll this up flat against the inside of the fender.
subyguy2 is offline   Reply With Quote
Old 03-11-2003, 04:38 PM   #7
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Get a body shop to do it.. You need to use a heat gun on it as well while its being done so if currys didn't use one that could be the reason it came out ishty. I believe Wagon Werks can do this
edit: heat gun not hairdryer
silverF4turbo is offline   Reply With Quote
Old 03-12-2003, 03:36 AM   #8
rex n effect
Member#: 15289
02 wrx pollen silv
thanks, tim.
When did you get it done. I'm just wondering if you've driven through all this crap on the road and the paint is still all intact.
Looks like I might have to pay cde a visit.
Has anyone else had it done somewhere else?
Old 03-12-2003, 08:28 AM   #9
mav1c
Hoodbridge!
Member#: 560
Yeah, driven through some of this crap, and everything is still perfect. Given, the car only had about 3K miles on it when I got the fenders rolled so everything was nice and fresh. I'm sure that helped.
Old 03-12-2003, 12:03 PM   #10
Nolift911
Member#: 33093
I used a Louisville Slugger on mine...$9.95 from Sports Authority...took about 7 minutes with a friends help...
This was on my 911 Carrera so a WRX may be different...but somehow I doubt it
Nolift911 is offline   Reply With Quote
Old 03-29-2003, 12:34 PM   #11
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Any other places closer to the Baltimore area? I went with 215's and I have hella rubbing. Any idea of what I can expect to pay? I know you can buy the tool for like $500 bucks, so I don't really think it should cost $200 to have it done.
Garret
Ghomer1 is offline   Reply With Quote
Old 03-29-2003, 10:08 PM   #12
Ghomer1
Member#: 8091
2007 335i
Anyone?
Old 03-30-2003, 06:42 AM   #13
Speed FX
Member#: 7831
New Shop now open
www.speed-fx.com
We have used the baseball bats .The paint did crack but we touched it up with under coating no problems.The lip is rolled under so no one sees it.But the Waiver is a must.
Speed FX is offline   Reply With Quote
Old 03-30-2003, 10:22 AM   #14
WRX11
Member#: 26638
Anyone got pics of their jobs?
WRX11 is offline   Reply With Quote
Old 03-30-2003, 10:44 AM   #15
N/A
Member#: 133
TBA TBA
TBA
I have used the old baseball bat or a piece of pipe wrapped in duct tape works fairly well also since it doesn't grind the metal against the paint as you do it.
N/A is offline   Reply With Quote
Old 03-30-2003, 11:20 AM   #16
Ghomer1
Member#: 8091
2007 335i
Hmmmm, baseball bats? Really?
Old 03-30-2003, 03:12 PM   #17
rex n effect
Member#: 15289
02 wrx pollen silv
i ended up using a wooden baseball bat, too. The paint will crack if your car is older, but you can't see it anyway, and you shouldn't have problems if you touch it up soon after. 245/40 17s fit great with minor fender roll in the rear only.
Old 03-30-2003, 03:29 PM   #18
Ghomer1
Member#: 8091
2007 335i
So how do you do this baseball bad method. Just stick it in between the tire and the fender and push up? Or what?
Old 03-30-2003, 03:36 PM   #19
N/A
Member#: 133
TBA TBA
TBA
Stick the bat between the tire and the backside of the fender at an angle at the rear of the fender and have somebody slowly give the car some gas so that it barely moves forward. Then have them slowly backup. Thats basically the short version.
Old 03-30-2003, 04:50 PM   #20
Ghomer1
Member#: 8091
2007 335i
That sounds really scary
Old 03-30-2003, 07:09 PM   #21
Speed FX
Member#: 7831
New Shop now open
www.speed-fx.com
We use 2 different size bats one is smaller then use the bigger one to flatten.....Sort of S&M with bats
Old 03-30-2003, 07:30 PM   #22
N/A
Member#: 133
TBA TBA
TBA
A few friends have taken their fenders off before and simply cut off the excess metal and then taped off the fender and covered the bare metal thats left with a rust proofing primer and then basic black paint.
Old 03-31-2003, 09:14 AM   #23
Ghomer1
Member#: 8091
2007 335i
I wouldn't have any idea how to take fenders off......lol
What kind of crab to use in a California roll? And where do I get it? perret318 Off-Topic 19 03-04-2006 09:44 AM
where did you get your LASIK done? jhayzhon Mid Atlantic Impreza Club -- MAIC 13 09-20-2005 09:51 AM
what lip is this and where can you get it? batmanalan Interior & Exterior Modification 10 04-12-2004 05:32 PM
WRX Koni inserts: Who has them, where did you get them, and who has them in stock? Cosworth Brakes, Steering & Suspension 4 09-13-2002 03:18 PM
When and where did you get your WRX? WRX_man20 Southern California Impreza Club Forum -- SCIC 52 05-29-2002 03:55 PM
