Old 03-11-2003, 02:28 PM   #1
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Default ProECM/TC2 Questions-- Mileage and Emissions
DISCLAIMER: This is NOT about the HP/torque performance of either chip brand. That issue has been beaten to death by several threads and I would like for it to not be discussed in this one.
Recently I've come very close to buying a ProECM or TC2 v2.7 for my 02 2.5 RS 4EAT. The only issues keeping me from buying one is the question as to whether installing a chip will decrease my mileage and increase emissions.
It has already been established that both chips act to increase ignition timing. Is there a correlation between an increase in timing and a decrease in mileage? If so, would the increase in timing be offset by adding 91 or 93 octane gas, as both chips require? If you have a chip in your NA Impreza, how has your mileage been affected?
What about emissions? If the timing is increased, would I be less likely to pass my states' emission test in a year or two? If you have a chip, what have your experiences been when you pull into the DMV or a private inspection shop to get your emissions tested?
Thanks in advance.
DrBoy01 is offline   Reply With Quote
Old 03-11-2003, 04:20 PM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2008 STi DGM (3rd
STI) prev 05 STi (white)
actually in this case, the increase in timing will increase your gas mileage if you don't drive too fast... Just like most any other perf. mod...
DanzBorin is offline   Reply With Quote
Old 03-11-2003, 05:17 PM   #3
joefocker20
Member#: 13745
2004 STI
Your car is also emissions exempt for 3 more years..
joefocker20 is offline   Reply With Quote
Old 03-11-2003, 06:51 PM   #4
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
An advance in timing should increase gas mileage. A decrease in mileage suggests that it also adds more fuel which hurts performance unless you have a lot done to the car. As in along the lines of heads and cams.
scoobiejosh is offline   Reply With Quote
Old 03-11-2003, 08:11 PM   #5
joefocker20
Member#: 13745
2004 STI
Im not sure if my Intake or my PROECM causes mycar to run more rich, I have a VERY sooted exhaust..
Old 03-15-2003, 04:38 PM   #6
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
With my TC2, my mileage is almost exaclty the same.
DoorKnob is offline   Reply With Quote
Cat and emissions question... MachinesWRX Newbies & FAQs 14 10-20-2005 12:27 AM
Downpipe's and emission/dealer questions. Jduke New England Impreza Club Forum -- NESIC 9 07-15-2004 07:16 PM
Downpipe's and emission/dealer questions. Jduke Factory 2.0L Turbo Powertrain 1 07-15-2004 11:56 AM
ProECM and Emissions testing ? Dr Ken Normally Aspirated Powertrain 3 01-02-2004 11:47 AM
Ack PROECM chip question and Cobb cams question. DoctorNick Normally Aspirated Powertrain 5 04-04-2002 11:38 PM
Message Board Statistics All times are GMT -4. The time now is 09:06 PM.
