Old 03-12-2003, 10:52 AM   #1
Supraru
Member#: 23313
99' 2.5Rs
black
Default Car eating an unusual ammout of oil
Ok, I have a 99' Rs and it eats about a quart every 1000 miles, maybe more. I have about 55'000 miles one it and have an intake and exhaust. I took it to the dealer and they said they didn't find any leaks (which there isn't) and they said they hooked up a scaner to the exhaust and didn't get any oil comming out of it. They took apart my intake and said there was oil just laying in the throttle body!!!! They said they got warnings from subaru about the intakes. They told me to keep an eye on it and bring it back if it gets worse. Well it's still eating oil and I cleaned the intake and changed the hoses for the intake. I checked the trottle body and there is no oil build up but it's still eating oil??? Where is it going and why won't the subaru dealer fix my car??? My friend did a Gsr motor swap on his civic and he had oil in his throttle body and his rings were shot. Is this what's wrong with my car? And how can I get it fixed under warrenty. I payed like $1,500 for the extended warrenty seems like it's a waste.
Supraru is offline   Reply With Quote
Old 03-12-2003, 12:28 PM   #2
jdk
Member#: 26114
06 rs
Its possible it might be the rings or piston,but first I'd buy a new PCV valve and see if it gets better. If problem remains have compression & leakdown test done to see if its one of the pistons.
jdk is offline   Reply With Quote
Old 03-12-2003, 12:50 PM   #3
Supraru
Member#: 23313
99' 2.5Rs
black
Thanks for the tip, I feel dumb asking but where is the pcv valve on our car.
Old 03-12-2003, 12:55 PM   #4
Supraru
Member#: 23313
99' 2.5Rs
black
Nevermind, found it on Scoobymods. I love that site.
Old 03-12-2003, 02:18 PM   #5
Puckaveli
Member#: 1518
00 2.5RS
Sounds like oil is blowing by the rings and getting in your intake track. The other thing is, did the dealership test for oil in the exhaust under load? Just revving the engine while it's sitting registers barely any load and the oil will blow by worse under heavy load. Don't hammer on the car until you get the problem figured out. I would do as they suggested above.
Puckaveli is offline   Reply With Quote
Old 03-12-2003, 02:29 PM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
OK, been here before... 1 qt/1000 mi is within factory spec (it sucks but it is). Some EJ25s had a bad batch of blocks that deformed over time and egg-shaped the cylinder walls. I had my block replaced at 60000 under warantee due to 2 cylinders being out of round. Get in touch with your dealer NOW!!! They will likely give you crap but they will need to establish an oil consumption log on your car which basically consists of an oil change and milage check and then you'll go back to the dealer at set intervals for an oil level check. Get this on the record before your 60k powertrain expires. Other than turbo/supercharer there is not a single bolt on that can be considered a cause... its bad metalurgy.
Old 03-12-2003, 04:30 PM   #7
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Although it sounds like the dealer is setting up to blame the intake.
You might consider swapping the stock intake/exhaust back on for a while.
CosmoTheCat is offline   Reply With Quote
Old 03-12-2003, 04:39 PM   #8
Supraru
Member#: 23313
99' 2.5Rs
black
It does sound like they are going to do that, but they are usually cool with that stuff. As a matter of fact my car is there now because my rear O2 sensor went. They have also replaced my friends o2 sensor even though he had a safc. Do you guys know of any hard proof that the intake wouldn't cause that? I know there is no way but if there is a way I could prove it I wouldn't have to put the stock air box back on.
Old 03-12-2003, 04:40 PM   #9
Supraru
Member#: 23313
99' 2.5Rs
black
Or does anyone know of a mod friendly Subaru dealer that wouldn't screw me around and fix my motor? I'm in Pa near Philly.
Old 03-12-2003, 09:02 PM   #10
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Ill tell ya what, I was the first in my area to buy 2.5rs(back in Sept '97) and I had a simular prob. I hate my dealership(Apple Subaru York,Pa) but thats another story. They told me the same thing (burning 1qt every 1000mi is the norm).I didnt find any in the intake but then again I never looked. I finally blew the engine at 49,550mi, just inside of the factory warrentee(close one ).
I ended traveling 50mi to another dealership who took care of everything no questions ask and they treated me like a PERSON (sorry had to vent). Anyway had the block replaced and I check the oil every so often and really had no problems since. So yes It could have been a bad batch of blocks or something. Make sure its taken care of before warrentee runs out, would of cost me $1900.
sti27 is offline   Reply With Quote
Old 03-12-2003, 09:49 PM   #11
Supraru
Member#: 23313
99' 2.5Rs
black
sti27 where did you end up taking your car? I'm about an hour and a half or so away, but if I can get my motor fixed I'll drive the distance.
Old 03-13-2003, 12:29 AM   #12
JohnP555
Member#: 20355
99 RS
Rally Blue Pearl
I see there is a mention of an oil consumption log. I have heard of this before but am not quite sure how it works. Does the dealer simply monitor your oil changes and how much oil you have left in your car at the change, and from that information determine to what extent your car is damaged or what is damaged (ie: cylinder walls, piston rings, etc...) Basically like a trial and error thing or is it more involved?
JohnP555 is offline   Reply With Quote
Old 03-13-2003, 01:31 AM   #13
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Default Supraru
I took mine to Hanover Subaru (I forget the name). I also heard Lancater Subaru is pretty cool. I was in Lancaster one day and had a CEL light up. I called L.S. and they were really nice on the phone.
Where are you from?
Old 03-13-2003, 10:08 AM   #14
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
JohnP555, I live ~120mi from the nearest dealer (awesome dealer, the drive sux balls though) so what they did for me may be a bit different than if you're closer but...
- Went in, had oil changed and logged and told don't touch it
- Went back in 1500 or 2000 mi (don't remember which) and checked again... oil was very low but technically still "within spec"
- Dealer called in District service guy since it was his call to make such a potentially large decission
- District guy (who loved the mods on my car ) took the car out for a 180 mi road trip after giving it oil/logging it.
- District guy came back, measured the oil, noticed a loss (albeit a small loss), metioned again how much he loved the car and wrote up a warantee ticket for the block
Old 03-13-2003, 06:48 PM   #15
Supraru
Member#: 23313
99' 2.5Rs
black
I'm right near King of Prussia.
Old 03-13-2003, 06:58 PM   #16
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
hanover subaru is a hour or so from my house and king of prussia is about 1 1/2 to 2 1/2 hours in the other direction. Dont know if you'll want to drive that far
Old 03-13-2003, 07:08 PM   #17
Supraru
Member#: 23313
99' 2.5Rs
black
Wow, that is really far. Does anyone else know of a place?
Old 03-14-2003, 12:01 AM   #18
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Lancaster is closer but isnt there one near you, or are they jerks also?
Old 03-14-2003, 12:24 AM   #19
slowlegacy
Member#: 30507
94 legacy
green
ugh. my cars eating a lot of oil but its way past warranty. changed oil a month ago and it was 2 1/2 quarts low last week. put more in and it lost another quart by today. no leaks or funny smells. i drive 250-400mi/week; not like this was on a roadtrip or anyhting. does this mean the engines on its way out? theres no way this cars getting $1900 in work
slowlegacy is offline   Reply With Quote
Old 03-14-2003, 09:43 AM   #20
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
92 legacy turbo? If so put the money into it, if not then yes it needs a new block or a rebore and matched pistons or a new set of rings, or a seal(s)... then again I haven't heard of the older EJ22s having this specific (egg-shaped cyl) problem. I assume you've checked the PCV valve, the valve cover breathers, etc to see where the oil is coming from? Look at your tailpipe, black deposits are usually unburnt fuel/carbon (which isn't always a bad thing) but if its oily then you've found your problem, your getting excessive blowby from something. Depending on milage it could be bad rings/seals in the motor, it could be the egg-shaped cyl walls, either way its gonna cost you. If I were you I'd start buying cheaper oil and check/refil frequently.
Need an unusual favour (will pay) : Can someone check this car out for me? SilverJS General Community 5 07-05-2009 10:19 PM
who's been homeless or lived out of their car for an extended period of time pjhe Off-Topic 21 03-19-2008 11:54 PM
did my car jus eat 4 qts of oil?? blurex02 Newbies & FAQs 5 11-04-2005 09:13 PM
so my car is leaking a lot of oil... how to clean? Keith Off-Topic 13 06-01-2004 07:47 PM
An extra quart of oil.. Bad? Big Turkey Service & Maintenance 4 07-14-2003 11:34 PM
