Old 03-12-2003, 03:56 PM   #1
jeffg
Member#: 2958
2001 6.0?RS
Default quick Q, poor milage and rough idle - Fuel filter?
Hey everyone. I have done most of the 30k service but I have not done the fuel filter. I thought I had one around the house, but I cant find it.
anyway, I have noticed that my gas milage has really gone down in the last several tanks. I have also noticed that my idle is pretty rough and there is a momend of hessitation on tip in.
Does this sound like a fuel filter problem?
J
jeffg is offline   Reply With Quote
Old 03-12-2003, 05:57 PM   #2
kickin_81
Member#: 16679
2004 Forester XT
When was the last time you checked your PCV valve or have your air filter cleaned/replaced? Do all three.
kickin_81 is offline   Reply With Quote
Old 03-13-2003, 01:15 AM   #3
nixx
Member#: 7581
2001 Impreza 2.5RS
Try replacing sparkplugs too.
If those don't work I say you need to replace your O2 sensors.
nixx is offline   Reply With Quote
Old 03-13-2003, 11:53 AM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
check your plugs, change your filter (they're cheap and can be bought from any auto parts store), try an ECU reset, if still bad PCV, then look at your O2 sensors.
Old 03-13-2003, 12:00 PM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I was thinking O2 sensor also.
Eric SS is offline   Reply With Quote
Old 03-13-2003, 12:43 PM   #6
jeffg
Member#: 2958
2001 6.0?RS
wouldnt an O2 sensor give a CEL?
I have done plugs, wires, air filter.
I did an ECU reset when I had to pull my Greddy Emanage.
I will do the fuel filter and PCV tomarrow and see if it helps.
J
Old 03-13-2003, 12:49 PM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
O2 sensors will go for a while without throwing a code. Jeff, you pulled the E-Manage? That was my next thought, the E-Manage but then again low milage should be expected with a piggyback ECU.
Old 03-13-2003, 01:09 PM   #8
jeffg
Member#: 2958
2001 6.0?RS
Yeah I pulled and sold the Emanage. Going to a Link+
Is there anyway to check and O2 sensor without a CEL?
J
Old 03-13-2003, 01:17 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Dealer's scan tool will read voltages and the dealer tech can look up acceptable values. Unfortunately unless you've got a real cool dealer the diagnostic will cost you. The code readers at the auto parts stores only read stored codes so you're kinda SOL.
Old 03-13-2003, 01:29 PM   #10
jeffg
Member#: 2958
2001 6.0?RS
We have an OBD reader on laptop. Maybe I will try that.
J
Purge Control Valve and rough idle LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-30-2010 11:48 AM
Cruise Control Recall and rough idle kensington Mid West Subaru Owners Club Forum -- MWSOC 12 04-30-2004 11:42 PM
Hard starts and rough idle Brooke Legacy Forum 3 12-12-2003 08:00 PM
Hesitation and rough idle JasonRan Electrical & Lighting 5 12-10-2002 01:31 PM
Sputtering and rough idle in the cold? EEK! GooseMan Normally Aspirated Powertrain 6 02-15-2002 12:50 PM
