Old 03-12-2003, 08:05 PM   #1
1quikrex
Member#: 15329
2015 WRX WRB Ltd
2002 WRX PSM (sold)
Default What is needed?
To run low 14 sec. to a high 13 sec. 1/4 mile in a N/A 2.5RS? This means no nitrous, is it very difficult?
1quikrex is offline   Reply With Quote
Old 03-12-2003, 08:42 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
you will probably need to get a higher compression motor, cam's and a full valve train.. exhaust, intake, suspension, and tires. a built motor (like cobb's) will allow you to rev higher (8k rpm redline), and make alot of N/A power.
rhdude is offline   Reply With Quote
Old 03-12-2003, 09:00 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Leave it all alone and strip the body down.
Old 03-12-2003, 09:32 PM   #4
joefocker20
Member#: 13745
2015 STI
Yeah, youre going to need around 10,000.. Anyway, I think with everything I'm going to be buying (Damn IRS takes money fast, but dosent give it up quick!) My car should be pretty quick, but this is still around 6000 in parts and labor for the cams and clutch. And I still haven't touched brakes or suspension, with the exception of tires, 20mm FHI Swaybar, and the Whiteline Rear Diff Lock Kit. Here's what I have so far:
Ganz CAI w/ K&N
PROECM Chip
20mm FHI Rear Sway
Stromung Catback w/ Kartboy Hangers (Hangers on Order)
Mr Joshs 1.19 lb pulley
Kartboy Shifter w/ MOMO Airleather
Sparco Pedals (On Order)
Kuhmo Ecsta 712s
Hawker 13.5 lb Battery
Whiteline Diff Lock Kit
STI "I" Badge"
Clear Sidemarkers
About 150 lbs removed
Here's what I'll be adding to the car shortly:
Brullen Headers and Cat
Cobb Street Cams
Bored TB
Exedy 9 lb Flywheel
Cobb Clutch
LW Bumper Beams
Should run pretty good times..
joefocker20 is offline   Reply With Quote
Old 03-12-2003, 10:28 PM   #5
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Buy my n/a power package, its a good start
in all serousness(heh sp?)
cams, intake, realy good free flowing headerback exaust, n2o, ported heads, shorten 3rd & 4th gear, lighten flywheel, strong strong clutch, and aftermarket engine management.
Aftermarket engine management is very important. The stock ecu is going to hinder majorly.
DoctorNick is offline   Reply With Quote
Old 03-12-2003, 10:30 PM   #6
joefocker20
Member#: 13745
2015 STI
I seen that for sale, but I just spent 5000 to move from NJ to CO, and I'm waiting for my amended income tax refund.. If you could do a fellow Nasioc'er a favor and hold onto the cams for me, I'd be much obliged
Old 03-13-2003, 11:02 AM   #7
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
With cams, header, pulley, intake, highflow cat, ProECM and a little here and there I was running with and beating most stock WRXs to 100-ish, figured about a 14.7 1/4 mi. The only way you're going to break into the 13's is to raise the effective compression of the engine and improve the breathing. Raising compression should be self explanitory... pistons. Breathing is both cams and heads (intake manifold and TB are quite good stock). You'll need to raise the redline to use the cams so now you're getting into valvetrain mods and either a unichip or full standalone ECU. At these power levels you'll probably have to close the block and maybe sleeve the cylinders. Then there's the clutch and tranny, stock tranny if babied should handle the power but if you tweak the gearing you'll be able to put down more/less power where you want it. Oh, then there is the weight... if you can loose a couple hundred lbs off the car many of the above mods won't necesarily be require but the car will likely not be street legal or safe (poly windows, CF everything, lightweight or no bumper beams, CF/FG bumper covers/fenders, FG/CF dash, you get the idea). Daunting huh?
This is why I went turbo
Old 03-13-2003, 11:40 AM   #8
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Default Re: What is needed?
Too much $$$ to be worth it...
DanzBorin is offline   Reply With Quote
What all has the EJ25, and what is needed for my swap? Karas Newbies & FAQs 2 10-04-2009 11:31 PM
What is needed to support the mods... Scoober01 Normally Aspirated Powertrain 15 07-13-2001 03:44 PM
What is needed to build rally car? SAM_463 Motorsports 14 03-27-2001 01:37 PM
What is needed to drop a ej20 TT in a 2.2L Impreza? >>> KaZ General Forum Archive 12 02-23-2001 07:48 AM
What is needed to make complete setup.... Rubasu Brakes, Steering & Suspension 7 11-18-2000 12:13 AM
