Old 03-12-2003, 08:25 PM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Unhappy Help car wants to overheat at idle
When I drive the car around the temp gauge reads normal and I drive about 60 miles a day on the freeway without problems. Only when the car sits at idle the temp slowly raises up, but never gets to the hot point. I turn on the heater full which is hot and it helps bring the engine temp down. Both fans are working properly, but they don't seem to be able to cool the engine enough. I think it's either a thermostat or soething blocking the coolant. Any ideas??
seven881 is offline   Reply With Quote
Old 03-12-2003, 08:37 PM   #2
live311
Member#: 10801
2008 Outback
Could be a bad thermostat, a blocked radiator, or maybe your fans aren't working as well as you think. When was the last time you had your radiator flushed? You may be due. I say take it to the dealer. Are you still under warranty?
live311 is offline   Reply With Quote
Old 03-13-2003, 02:14 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like a slightly stuck thermostat...that or a faulty water pump.
jeremy
Old 03-13-2003, 07:40 AM   #4
seven881
Member#: 8828
01 BRP 2.2T Hybrid
There is a small leak coming from where the water pump mates to the block, but it's been like that for awile now. I'm doing a EJ22T swap soon, so I think I'm going to change the water pump and thermostat to be safe. Thanks fellas.
Old 03-13-2003, 11:14 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you need a water pump, that leak is coming from the water pump weep hole, that tells ya when the pump is bad.
Jeremy
Old 03-16-2003, 09:58 PM   #6
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Changed water pump and she's back to normal. Thanks again.
Car started to Overheat...Thermal Switch? enjoiwrx Service & Maintenance 2 11-08-2009 02:42 PM
Steering doesn't want to turn at idle ? GuitarkidM3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2009 11:22 PM
Car overheats at idle when AC is on--HELP! wjc04wrx Service & Maintenance 5 05-06-2007 08:48 PM
Aargg!!! Help!! Car refuses to idle, just dies scooterforever Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 04-19-2005 01:36 PM
my car is stuttering bad at idle.. please help SubyBean Normally Aspirated Powertrain 14 01-25-2004 04:30 PM
