Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 03-12-2003, 09:48 PM   #1
FLaBrit
Member#: 19135
2002 RS
Default What makes an Outback?
or more speciffically...what exactly are the differences in suspension between the Legacy wagon and the Outback? If there is a difference how much of the aftermarket suspension stuff for the Legacy fits the Outback? What is the best route to take to improve it's handling?
FLaBrit is offline   Reply With Quote
Old 03-12-2003, 10:54 PM   #2
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
I'm pretty sure there are spacers on the chassis to give it a little bit of lift. As for changing the handling, new struts would probably help stiffen up the ride.
I've also seen some folks do full swaps with GT suspension. Drops the car quite a bit, but you lose ground clearance. I had thought about modifying the suspension of our new OBS, but we actually take it offroad quite a bit--especially in Ocala National Forest. Give me my forest map and GPS and we'll have a blast!
Also, good to see a fellow Florida member as well.
Matt is offline   Reply With Quote
Old 03-13-2003, 12:40 AM   #3
Crawdads
Member#: 30907
SWP GDB-G
Although it has been covered a billion times....
The blocks between the suspension subframes are there to correct the suspension geometry, not to lift the car.
the Outback gets its lift from the spring perches on the strut being located higher.
but a search will pull up all the different suspension mods that OB folks have done, you should find stuff pretty easy.
good luck
-r
Crawdads is offline   Reply With Quote
Old 03-13-2003, 08:20 AM   #4
DaveM
Member#: 4503
2012 Imp Sport Ltd
Camellia Red
good luck
-r
In addition to the higher spring perches, the larger tires also give it approx. another 1/2" lift.
DaveM is offline   Reply With Quote
Old 03-13-2003, 01:56 PM   #5
Crawdads
Member#: 30907
SWP GDB-G
oh yeah, i guess i thought that was obvious, but good point.
Old 11-25-2006, 10:27 PM   #6
Wingman707
Member#: 132600
Default Cobb Tuning
I don't know if it is bad form to post a suggestion with out actually purchasing from the said company. You should check out Cobb Tuning out of Salt Lake Utah. They have some of the best "looking" aftermarket Subaru exclusive equipment that I have seen. The only reason I haven't purchased from Cobb, is simply they don't make anything for my H6. Good luck
Wingman707 is offline   Reply With Quote
Old 11-26-2006, 12:37 AM   #7
97obw
Member#: 109426
97 OUTBACK
mud brown
dropping an outback would take 75% of the offroading run out of it!
97obw is offline   Reply With Quote
What makes an Access database big (MB-wise)? sonicblue Off-Topic 36 11-29-2004 04:23 PM
Help!!! I need an Outback in OC/LA... (and maybe make some money while you're at it) aerykwoo Outback Forum 1 11-25-2004 03:46 PM
Help!!! I need an Outback in OC/LA... (and maybe make some money while you're at it) aerykwoo Southern California Impreza Club Forum -- SCIC 13 11-09-2004 03:52 PM
what make a 2002 outback an outback? flyingmachine Newbies & FAQs 4 12-09-2003 04:51 PM
What would GT springs do to an Outback? Is there a better choice? dvancleve Legacy Forum 12 03-30-2001 07:05 PM
