Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 03-13-2003, 03:28 PM   #1
Smash!
Member#: 31124
2002 WRX Sedan
Question Left front tire wear more than the other 3?
My left front tire is rounding out on the outer edge. I just swapped RS rims with my WRX stock and notice it. Drove a 100 miles on Kumho 712(used, about 9k on them) and the front left tire is starting to round out like the RE92. Can it be something else that's causing the problem? I have whiteline 24mm front sway and 22-26mm rear sway. That's the only change to my suspension. Any ideas as to the cause of this?
Smash! is offline   Reply With Quote
Old 03-13-2003, 03:34 PM   #2
Smash!
Member#: 31124
2002 WRX Sedan
I left out that I've just done an alignment and the numbers didn't change much. Here's what I've got:
Front
Initial After
Caster
Left 3.3 3.6
Right 3.5 3.8
Camber
Left -0.6 -0.8
Right -0.2 -0.8
Toe
Left 0 0
Right -0.1 0
Rear
Camber
Left -1.6 -1.6
Right -1.3 -1.1
Toe
Left 0 0
Right -0.15 0.5
Any thoughts?
Old 03-13-2003, 03:35 PM   #3
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
Assuming you have not damage to your suspension, your alignment is out of spec. You probably have some toe issues on that corner that need to be changed. Get yourself an alignment asap!
Cosworth is offline   Reply With Quote
Old 03-13-2003, 03:55 PM   #4
driggity
Member#: 7453
2005 Legacy GT Wagon
5MT/Cloth Limited Edition
Alignment doesn't look like it would have caused it in the front. Have you checked tire pressures?
Does look like your alignment got worse in the rear though. Bigger difference in both camber and toe than there was before. I would have bitched about that.
driggity is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 03-13-2003, 04:36 PM   #5
STX_REX
Member#: 25255
MBP (I washed It)
Do you take alot of on and off ramps at speeds the the local authorities would frown on?
STX_REX is offline   Reply With Quote
Old 03-13-2003, 04:41 PM   #6
Smash!
Member#: 31124
2002 WRX Sedan
well.....yeah....but why only the left front is wearing down faster than the other 3 and rounding on the outer edge? That bugs me.....not to mention it's messing up my tires.
Old 03-13-2003, 09:17 PM   #7
tdxflex
Member#: 13634
how are your tire pressures, maybe you have a slow leak in the left front.
tdxflex is offline   Reply With Quote
Old 03-13-2003, 09:22 PM   #8
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
...but he had the same problem with the WRX tires that he is currently having with the RS tires. I say it's an alignment problem.
Albert is offline   Reply With Quote
Old 03-13-2003, 09:24 PM   #9
Smash!
Member#: 31124
2002 WRX Sedan
Tire pressure is good. 38psi front, 36psi rear. Then again, I just put on the Kumho 712 with the RS rims the day before. But looking at the RE92 from my WRX rims the front left wears more than the front right. This morning I notice the left front is rounding so I took it in for a alignment as the results posting above.
Old 03-13-2003, 09:27 PM   #10
Smash!
Member#: 31124
2002 WRX Sedan
Forgot to mentioned the left front wears more than the right front. The right front wears more than the rear. The rear has 70% tread while the front has 45% and 55% respectively.
Old 03-13-2003, 09:41 PM   #11
tdxflex
Member#: 13634
all the wear is on the outer edge? your alignment specs in the front were fine. and also he was running more negative camber on the left side than the right so if anything the right should have been wearing faster. no accidents or curbing either?
Old 03-13-2003, 09:48 PM   #12
yuletak
Member#: 3602
2002 wrx silver
1992 kawasaki ex500
Default high speed turns?
doing a lot of those cornering to the right or high speed curves to the right? i think that's what happened to my front left as well. most turns (hwy on/offramps) cause me to turn to the right, so that explains it in my situation.
yuletak is offline   Reply With Quote
Old 03-13-2003, 09:49 PM   #13
Smash!
Member#: 31124
2002 WRX Sedan
No accidents. Actually the rounding only occurs more to the left. The rest of the tire has normal "aggressive" driving type of wear. Normal wear on the right front tire( it actually HAS a shoulder, unlike the left, which is now round).
Old 03-13-2003, 09:50 PM   #14
Smash!
Member#: 31124
2002 WRX Sedan
hehe, maybe I should learn how to swing the rear out to "even" the wear. But that's a high possibility.
Old 03-14-2003, 06:47 AM   #15
STX_REX
Member#: 25255
MBP (I washed It)
The left front takes the most weight and or abuse when making a right turn. the added weight will cause the tire to roll and this will cause the shoulder to be rounded off.
PS. from what I've read, it is not a good idea to run uneven tire pressures in an all wheel drive car for extended periods of time.
later,
Andy
Old 03-14-2003, 04:00 PM   #16
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Default Re: Left front tire wear more than the other 3?
I still think you have an alignment problem if you can notice excessive tire wear after only 100 miles of driving. However if you are an admitted insane deranged unbalanced madman behind the wheel then that's a different story
Old 03-14-2003, 05:03 PM   #17
Smash!
Member#: 31124
2002 WRX Sedan
Dude, I live in LA. Traffic sucks around here....so yeah what you said...
Old 03-14-2003, 05:21 PM   #18
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 362
fix the loose nut ......
the one behind the steering wheel ;-)
it doesn't look like an alignment problem if the specs you posted are correct ... it has to be either air pressure issues or the driver
Old 03-14-2003, 05:46 PM   #19
Smash!
Member#: 31124
2002 WRX Sedan
It could be me, but I failed to mentioned that the car doesn't track straight and pulls to the right. Again, the only thing that change are the sway bars, rims and tires. Obviously the difference in tire wear is an contributing factor. I am suspecting the rims or possibly the front sway(shifting left or right maybe). If the wheels are not balance, it would shake when I brake, right? It doesn't shake when I brake but does pull to the right when I let the steering go. What do you think I should do next to troubleshoot?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:01 PM.
