Old 03-13-2003, 05:30 PM   #1
joefocker20
Member#: 13745
2015 STI
Default Cobb Spicy Cams
Nevermind, I just realized that these would never pass emissions, so below are my final plans, no earth shattering plans here..
20mm Rear Swaybar
Stromung Catback
Dynabatt Battery
PROECM Chip
Kartboy Hangers
Sparco Pedals
Kartboy Shifter
Momo Knob
Whiteline Diff Lock
Kuhmo Ecsta 712s
Mr Josh's Pulley
Brullen Headers
Cobb Street Cams
Upgraded Valve Springs
Titanium Retainers
Slightly raised redline
NX Kit
ACT Clutch
Exedy Flywheel
Bored TB
Koni Inserts
Cobb Springs
Goodridge SS Lines
Lightweight Bumper Beams
Cobb CAI
Hows this sound?
joefocker20 is offline   Reply With Quote
Old 03-14-2003, 12:35 PM   #2
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
sounds like a good choice of mods to me.. thats about everything i'd like to do to my car. you should look into putting her on a diet since you have 02 RS. also maybe some bigger brakes or just even pads would do. good luck!
imprezey is offline   Reply With Quote
Old 03-14-2003, 01:07 PM   #3
AntonioS
Member#: 23233
2000 2.5RS-T
white
Joe how do you raise the rev limit??
AntonioS is offline   Reply With Quote
Old 03-14-2003, 01:29 PM   #4
joefocker20
Member#: 13745
2015 STI
Well, either with a unichip and a unicchip rev module, or Cobb Access Flash when they develop it for the EJ25.
Old 03-17-2003, 11:58 PM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
TorqueChip.com will take your ECU and raise the rev limit to 6800-7800 with a torque chip built inside and extra timing retard under boost for $700.
This and a fuel pump seems to be enough for 7 psi up here with no other engine management...
ImprezaRS dot com is offline   Reply With Quote
Cobb Spicy cams passed emisions... Matt Monson Normally Aspirated Powertrain 21 11-04-2004 01:53 PM
Cobb Spicy Cams (Stage II, N/A) JonofScio Normally Aspirated Powertrain 1 07-16-2004 06:18 PM
Cobb Spicy CAMs for 2.5 SOHC slamck Private 'For Sale' Classifieds 26 12-09-2003 08:48 PM
Cobb CAI, Borla headers, Brullen cat-back, Unorthodox UD pulley, Cobb Spicy cams. yamarocket630 Car Part Reviews 2 12-21-2001 03:58 PM
Cobb spicy Cams!! Santo Domingo 2.5 RS Normally Aspirated Powertrain 17 09-10-2001 04:26 PM
