Old 03-13-2003, 04:33 PM   #1
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
Question Can I remove the heat sheild from the exhaust?
From driving around in all the snow this year, one of my heat sheild has decided to start rattling.
Can I just pull all of them off, or should i just try to tighten it.
thanks
Jiffy
SubaruWRC is offline   Reply With Quote
Old 03-13-2003, 04:44 PM   #2
Slack
Member#: 17548
Take it off...it will continue to rattle. If the bolts are rusted, then just take some plyers and bend the corners up and down till it breaks. Trying to mess around with wd40 is just too time consuming for my tastes.
Mick
Slack is offline   Reply With Quote
Old 03-13-2003, 04:46 PM   #3
Foz
Member#: 1776
2000 2.5RS
BRP
I pulled mine off and no more annoying rattling noise.
Just make sure you don't park on areas with lots of tall grass.
Foz is offline   Reply With Quote
Old 03-13-2003, 05:47 PM   #4
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
Can i take the ones off of the cats tool
Jiffy
Old 03-13-2003, 06:59 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Jiffy
Yup. Those are the ones that were actually rattling on my car, but I found out that there were like 4 or 5 rather large pebbles floating around in there causing the noise!!! So I just removed them and put it back on and its all good
Old 03-13-2003, 10:19 PM   #6
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
Took all mine off...was like it for nearly 2 years..no ill effect
b_tapper is offline   Reply With Quote
Old 03-13-2003, 11:34 PM   #7
joefocker20
Member#: 13745
2015 STI
How much do all of the heat shields weigh? I guess it may be worth it just to take them off when I order my headers and put them on.
joefocker20 is offline   Reply With Quote
Old 03-14-2003, 02:32 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I dont know, 5-10lbs including the bolts?
Old 03-14-2003, 02:35 AM   #9
joefocker20
Member#: 13745
2015 STI
Hmm, more weight reduction
I almost cut my fingers off every time I do exhaust work on my car anyhoo..
Old 03-14-2003, 07:11 PM   #10
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
Well, i succeeded in getting those bastards off, they are a pain in the arse. The vibration seems to be gone. Taking a test drive now to find out.
Jiffy
Old 03-14-2003, 07:14 PM   #11
joefocker20
Member#: 13745
2015 STI
I hope so, my car rattlesbadly for a 02
Old 03-14-2003, 08:31 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Ill play devils advocate.
SOA is "frugal" when it comes to adding items, later year models usually end up with features missing even.
Subaru wouldnt spend the money or time with heatsheilds unless they made a significant difference in some area. It could be safety, in which case you can make a judgment.
What if the heat sheild you remove prevents excessive heat from entering the transmission and causing premature wear and fluid break down?
Or what if the one you remove keeps the power stearing rack from melting down?
Old 03-14-2003, 08:43 PM   #13
joefocker20
Member#: 13745
2015 STI
Nuff said.. Its so nothing gets hot and catches grass on fire.. And I dont know about you, but my steering rack is not back that far..
Old 03-14-2003, 09:12 PM   #14
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
Jiffy
Still not gone, i maybe the sheilds on the cats, ill find out tommorow.
Jiffy
Old 03-14-2003, 11:31 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
joefocker20: Your stearing rack is not back that far? That makes no sense, I think you should climb under your car and look.
The exhaust ports on each head are in front of the cross member, your stearing rack is INSIDE the cross member. That means at some point the exhaust will have to cross over the stearing rack, unless you dump the exhaust in front of the front wheels.
Old 03-15-2003, 06:31 PM   #16
Foz
Member#: 1776
2000 2.5RS
BRP
SubaruWRC..
Check the ones from the front Y pipe exhaust (left or right). It was one of these heat shields that caused our rattles.
Old 03-15-2003, 11:50 PM   #17
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
i haven't had mine on for ~ a month.
jasona is offline   Reply With Quote
Old 03-16-2003, 05:00 AM   #18
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
I'll just take what he says as "if you take them off don't drive the front wheels past dry grass." I think that's good enough.
Dan
Merdock777 is offline   Reply With Quote
Looking For used Subaru SPT intake Heat shield just the heat shield For 06 WRX Cobb2006WRXJR Private 'Wanted' Classifieds 0 11-13-2009 12:35 PM
How do you guys deal with the heat? I'm from the midwest visiting Texas skribblez32 Texas Impreza Club Forum -- TXIC 43 04-10-2008 07:12 PM
Has anybody removed the heat shield under the hood 03clipsegts Interior & Exterior Modification 16 07-02-2007 08:35 AM
Can I take off the heat shield over the turbo? subeesteve25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-22-2006 08:37 PM
Anyone remove the heat shields? Ryan24 North West Impreza Club Forum -- NWIC 7 04-26-2002 01:06 AM
