Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 02-01-2005, 06:56 PM   #26
whoosh
Member#: 40989
OT vag inspector
mines stock
whoosh is offline   Reply With Quote
Old 02-13-2005, 10:04 PM   #27
RacingBlue
Member#: 3325
Just get a complete trans from Australia. The smaller displacement Foresters have a dual range internal gear box set up much like the old Brats. Should drop right in.
RacingBlue is offline   Reply With Quote
Old 02-15-2005, 12:30 PM   #28
cboggess
Member#: 30804
87 Yugo
Red
Originally Posted by outbackwbeer!
[email protected] has successfully mated a Nissan dualrange transer case to the Subaru! contact him for details .He's located in Eugene,Or.
My outback is going to be lifted with H6 springs1/2"/subaxtreme strut lift 35-40mm and a factory baja body (1" liftspacers")
It will make my outback ready for serious offroad. here's a
pic before the lift.
Where did you get that very sweet pushbar?
cboggess is offline   Reply With Quote
Old 02-16-2005, 02:16 PM   #30
cboggess
Member#: 30804
87 Yugo
Red
I'm going to have to see if my wife will let me put one on hers.
Old 02-21-2005, 01:06 AM   #31
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Ok I 've located and purchased a full set of King Springs 1.2" lift so it's gonna happen soon........just gotta get wheels/mud tires! I will post pics when done. In the mean time I did a DIY"Ganzflow"CAI and a 2.25" cat back with Magnaflow muffler! Subie growls now!
outbackwbeer! is offline   Reply With Quote
Old 02-25-2005, 12:08 AM   #32
lukeg199
Member#: 64433
2000 outback
green
Originally Posted by outback2.5HO
Thanks for posting the pics for me.
Sorry it took so long, I've been leaving my digi at work until a couple of days ago...
The Mod List:
___Rear 4:11 LSD From '00 RS
I just recently got my OB stuck in a ditch and i bet anything i would have gotten out if 3 wheels were turning instead of 2. How did you go about finding your LSD??? Junkyard? I definetely do not want to spend the $800 something that isr is selling them for. Thanks!
lukeg199 is offline   Reply With Quote
Old 02-27-2005, 07:36 AM   #33
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Rally Stuff lift in progress!
I'm half way there! I lifted the back with King springs Ksrr-29's about 40min r/r. before height at factory diffguard was 7 7/8" after was 9 3/4" ! Nice springs too beefy! 25% stiffer & nice yellow color! I have a raked look for now and the handling is much tighter! I'l post pics when done.
I'll get the fronts(KSFR-32) done soon and an alignment as well and full road /offroad test.
Old 02-28-2005, 01:43 PM   #34
outback2.5HO
Member#: 15135
95 GF WRX
You can get a used one from a parts yard from a 00-01 RS w/ axles for less than $400 usually. Other rear LSDs are out of 00 up Outbacks with cold weather pkg or Ltds, H-6s, LL beans, VDCs, or 00 up Foresters w/ cold weather (S, S premium, XS, XT). Make sure that the gear ratios are the same. If your car is manual, you have 4:11s which are pretty easy to find. Autos have 4:44s for the most part. Hope this helps...
outback2.5HO is offline   Reply With Quote
Old 02-28-2005, 01:47 PM   #35
outback2.5HO
Member#: 15135
95 GF WRX
Halfway there.. what happened a half rack?? You'll notice a nice difference off road when you get the fronts on. King makes a good product for sure.
Old 03-01-2005, 03:54 PM   #36
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Rally Stuff update on lift
I ran outta time to do the front(family) . So last night I started on the front. I took one strut/spring apart only to find the spring retainer was larger in dia. than the King spring.........Doh!
So today I went to the dealer parts and we found a forester spring retainer/rubber seat(on order) so hopefully tommorrow night I'm fully lifted!!
Old 03-02-2005, 02:55 PM   #37
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Rally Stuff lifted at last!
I finished my lift last night.......I now have almost 2" clearance using just the King springs. Ride is alot stiffer /tight. Now I just need some offroad tires/wheels. I'll post pics soon!
Old 03-02-2005, 02:59 PM   #38
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Talking clarification
I was refering to clearance from stock(2" higher) I went from 7 7/8" to 9 3/4" clearance. Measurements were taken at rear diff guard and front(primitive skid plate)
Old 03-09-2005, 03:07 PM   #39
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
lifted!
Old 03-09-2005, 03:15 PM   #40
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
actually I got about 2" of lift .
Old 03-15-2005, 10:09 PM   #41
lukeg199
Member#: 64433
2000 outback
green
I am also considering putting a 2 inch lift on my OB. However, i am concerned about losing the down travel. Have you ever had a problem with the suspension fully extending too early? Also do you know if this will effect any other part of the suspension/drivetrain since it is not in the normal, stock resting position? It is pretty important that i have a suspension that will keep me on the ground because i drive pretty fast on frost heav happy Vermont roads. Thanks alot!
Old 03-18-2005, 10:25 AM   #42
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
sounds more like a tire problem with frosty roads......get some blizzaks! By the way the suspension is much better lifted due to a stiffer spring, no pitch and roll gives you more traction in corners. as far as down travel goes it really won't affect it until you unless your gettin big air(rally style)! I mean you don't have a rally car or do serious 4 wheeling do you? I personally think the springs make the car handle like a sportscar than a rolly polly wagon. you feel everything under you which is good . Makes your car more dependent on your tires, in wich case get better ones!
Old 03-18-2005, 11:46 AM   #43
baja03
Member#: 83018
2003 Baja
dark blue
What kind and what size tires are on you OB
baja03 is offline   Reply With Quote
Old 03-25-2005, 06:40 AM   #44
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Rally Stuff tires
Currently I have BFG traction ta's 225/60R16's on WRX 16" rims.
I plan on getting a set of 15" wheels and Kumho Venture MT 235/75R15's For serious offroad & rally-X.
Old 04-17-2005, 02:55 AM   #45
The Undead Subaru
Member#: 70186
2006 Impreza
SGM
outbackwbeer!, where did you find all your parts and how much did it cost you all in all to lift your outback, im looking into lifting mine too
The Undead Subaru is offline   Reply With Quote
Old 04-19-2005, 04:30 PM   #46
old school
Member#: 22647
2016 Crosstrek
CWP
Here's my OBS . . .
Sports 27/8.50/14 Kumho Venture MTs like Outbackwbeer is looking to get.
I have Outback struts on it, jsut need to add springs for another 2 inches.
old school is offline   Reply With Quote
Old 04-22-2005, 06:27 AM   #47
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Rally Stuff sweet!
were you at rally-x......? I think I saw your car. nice setup
Old 04-22-2005, 11:18 AM   #48
old school
Member#: 22647
2016 Crosstrek
CWP
That was me. It will be taller next time.
Old 04-22-2005, 01:23 PM   #49
Vacca Rabite
Member#: 55491
WRX, 1968 Jeep m715,
1976 VW Porsche 914
Hey, could you put the image right on the board for us? I'm lazy and don't want to have to register... But I am interested in rasing up my OBS...
Zach
Vacca Rabite is offline   Reply With Quote
Old 05-06-2005, 03:29 AM   #50
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Rally Stuff offroad update
I have been busy modding my outback grinding calipers to fit 15" rims (front), a cargo basket I fabbed/welded for my spare,shovel....new tires(yokohama geolander AT+II's 215/75R15's/Konig wheels 15" with 40mm offset. a winch/more lift........!
lifted outback sports dmdellicolli Brakes, Steering & Suspension 12 09-03-2008 10:31 PM
Lifted Outback Allied Armament Outback Forum 3 04-15-2006 03:19 AM
Anyone have a lifted Outback Sedan? jsavage Outback Forum 8 03-01-2006 04:44 AM
Suspension/body lift, Lifted outback Legacy "BEEFY" Allied Armament Brakes, Steering & Suspension 0 11-27-2005 10:56 PM
Anyone own a lifted Outback? JC Legacy Forum 22 03-04-2003 03:14 AM
