Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 02-12-2011, 12:42 PM   #151
cstuck
Member#: 245172
1999 Legacy Outback
Olive Drab and Black
I've been really busy with school and work so i havent had much time to do any work on the subie. I found a good deal on craigslist for a set of 5 Jeep wrangler wheels for $100 so that is my next issue is making them fit. I ordered spacers from adaptitusa.com and they work but fender cutting and rolling is in order. Also started fabricating some of the front bumper, hopefully over spring break ill have a day or two to get some things done.
its starting to come together.
just need money and time
cstuck is offline   Reply With Quote
Old 02-13-2011, 09:05 AM   #152
limeylight
Member#: 5428
97 Legacy Outback
WOW, holy offset Batman!
I found this post ironic in that I recently used some adapters to mount STI rims on my Jeep and here you are mounting Jeep rims on your Subaru. I'd be a little concerned that those adapters aren't hub-centric though. You might suffer some vibration. Here are mine:
http://www.dirtyimpreza.com/forums/s...149#post236149
limeylight is offline   Reply With Quote
Old 02-14-2011, 08:29 PM   #153
cstuck
Member#: 245172
1999 Legacy Outback
thats odd but really cool. Ive already put them on and they are drilled to fit my hubs perfectly. the guys at Adaptitusa.com called me to make sure it was right.
Old 02-15-2011, 07:21 AM   #154
limeylight
Member#: 5428
97 Legacy Outback
The adapters may be hub-centric to the car but they lack the spigot that would mate up to the hole in the Jeep wheels so the package is effectively not hub centric. It may not be an issue but the excess offset will likely exacerbate any mis-alignment in there.
Old 02-17-2011, 02:25 PM   #155
cstuck
Member#: 245172
1999 Legacy Outback
I understand what your saying man. But so far i haven't had any issues with it. But it hasn't been off the pavement yet. With time it might act up or become slightly unbalanced but for now its all good.
Old 02-17-2011, 04:57 PM   #156
limeylight
Member#: 5428
97 Legacy Outback
Hey, if it's good it's good.
Old 04-30-2011, 03:18 PM   #157
mnfire
Member#: 236081
2001 Outback
I am looking for some help with lifting a 2nd Gen Outback (2001) with 04+ forester suspension. anyone done this?
mnfire is offline   Reply With Quote
Old 04-30-2011, 03:31 PM   #158
skunkman
Member#: 118141
95 'lifted' legacy
the front will bolt in but 2nd gen OB has a different rear suspension, so the FOR stuff won't work...
skunkman is offline   Reply With Quote
Old 05-02-2011, 12:06 AM   #159
mnfire
Member#: 236081
2001 Outback
Yea I am aware the suspension is differnt, but I could I hae swore I saw one on here with forester suspesion...
What kinda of things would need to be done to try to make forester suspension wrkon a gen.2 outback? or not worth t effort?
Old 05-02-2011, 02:14 PM   #160
skunkman
Member#: 118141
95 'lifted' legacy
check here (http://www.subaruoutback.org/forums/...ack-wagon.html)
for how best to lift your generation OB...
Old 05-09-2011, 09:53 PM   #161
madaff920
Member#: 268304
Originally Posted by cboggess View Post
Where did you get that very sweet pushbar?
ya really i want one!!!
madaff920 is offline   Reply With Quote
Old 05-29-2011, 07:45 PM   #162
chatch82
Member#: 232256
2002 Bugeye WRX
Stage2 Protuned
i have a 2000 outback wagon..................what do i need to do a cheap lift? forrester suspension?
chatch82 is offline   Reply With Quote
Old 06-01-2011, 12:03 AM   #163
skunkman
Member#: 118141
95 'lifted' legacy
see post 160
2000 and newed have a different rear suspension than pre-2009 foresters...
for a 2000 OB, look at outback H-6 or baja springs...
or lift blocks from subtle soultons or jackson rally.
Old 06-01-2011, 12:28 PM   #164
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
How is this for lifted?
I took these pictures in Blissfield, Michigan.
Old 06-01-2011, 04:49 PM   #165
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
^ NICE! A little tall for me though and needs the frame tucked back up. I wonder what powers it?
calgearhead is offline   Reply With Quote
Old 06-03-2011, 12:23 AM   #166
skunkman
Member#: 118141
95 'lifted' legacy
solid axles, frame, leaf springs...
Nice bolt-on wagon body!!
There were pix of a huge balloon-tire gen 1 legacy from iceland, or norway, or some fun, icy land to the north east.... anyone see that one?
Old 06-08-2011, 11:31 PM   #167
allthejerretts
Member#: 285159
I have a 1996 Subaru Legacy Outback. I just sold a Tahoe with 31's and a 3 inch lift. so as far as I can tell my outback is stock. I am wanting to ad some height to it, but I don't want to spend a lot of money and I kind of want it to be an easy job. Thanks
allthejerretts is offline   Reply With Quote
Old 06-09-2011, 02:59 PM   #168
allthejerretts
Member#: 285159
Originally Posted by outback_97 View Post
Here's outback2.5HO's sweet wagon:
Nice!
what kind of lift is this. and where did you get the parts
Old 06-09-2011, 03:02 PM   #169
allthejerretts
Member#: 285159
Originally Posted by rockhopjohn View Post
Looks good but you could saved a lot of dough if you had gone with the General Grabber AT2. Almost exactly the same tread pattern and at least $30 less per tire. I have them on my Outback, and I am convinced they are every bit as good as the BFG.
I gave the General Grabbers on my Tahoe, I will say they are just as good as BF
Old 06-09-2011, 08:27 PM   #170
skunkman
Member#: 118141
95 'lifted' legacy
For a 96 outback AND simple, i would suggest loking for some gen 2 Forester struts. Likely plenty here on NASIOC from folks getting out of stock suspension. 2002-2008 forester strut assemblies (complete strut, spring and top hats) will be bolt-on and give your outback 2+ inches, allowing for taller tires (which would provide more lift. So with a 2002-2008 forester strut swapo and tires you'd gain 3ish inches ground clearance for 3 nuts and 2 bolts per strut.
Old 06-09-2011, 08:28 PM   #171
skunkman
Member#: 118141
95 'lifted' legacy
+2 and with a slightly more open lug, they shed snow and mud better than the BFGs.
Old 06-09-2011, 10:00 PM   #172
allthejerretts
Member#: 285159
Thanks
Old 07-02-2011, 10:17 AM   #173
bumping wagon
Member#: 284937
98 Outback
Is this the same for a 98 OB Limited??
bumping wagon is offline   Reply With Quote
Old 07-03-2011, 12:07 PM   #174
JDMChizad
Member#: 159058
05 LGTx2/Baja T/OB
SWP/GRP/SWP/SPG
Yeah. All Outbacks use the same suspension '96-'99. I would recommend 1" rear spacers along with the Fozy suspension. You can get them through Subtle Solutions.
JDMChizad is offline   Reply With Quote
Old 07-03-2011, 04:10 PM   #175
junkyardgabe
Member#: 130968
09 Forester XT
Red
05 Outback XT with 1" strut spacers and bump the tires size up from a 225/55/17 to a 225/65/17
02 Outback sport with forester susp. and 215/60/16
junkyardgabe is offline   Reply With Quote
lifted outback sports dmdellicolli Brakes, Steering & Suspension 12 09-03-2008 10:31 PM
Lifted Outback Allied Armament Outback Forum 3 04-15-2006 03:19 AM
Anyone have a lifted Outback Sedan? jsavage Outback Forum 8 03-01-2006 04:44 AM
Suspension/body lift, Lifted outback Legacy "BEEFY" Allied Armament Brakes, Steering & Suspension 0 11-27-2005 10:56 PM
Anyone own a lifted Outback? JC Legacy Forum 22 03-04-2003 03:14 AM
