#1 |
Member#: 33990
Vehicle:09 WRX STI Lightning Red |
I have a hellix Dp, and a Greddy cat back with a perrin short basically an stage 2 kit from txs, ? is can I jus call txs and tell them to program the chip for stage two or how does this work, also what all else needs to be done if anything? any help will be appreciated. thanks
#2 |
Member#: 33990
ttt
#3 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
You have close enough to a stage 2 that it should work fine. All you do is order a UTEC from somewhere and when you install load the stage 2 map in whichever switch position you want.
Other than that you just install it and check to make sure your not knocking (if you live in the cold, winter gas, or low octane state). Seth |
#4 |
Member#: 33990
Thanks man, I live in bout mid climate area it gets cold here bout as low as 7 degrees or close to there and my octane rating is 93 so I hoe I would be ok.
How do u download and where from and also what is a switch position? Thanks for the info |
#5 |
Member#: 7922
You download the maps right from TXS. It's linked on the Utec page on their website. Try not to run random maps from other people, as each car is surprisingly different, to make sure you don't blow something up.
As for the switch, it a switch on the side of the UTEC that allows you to change which map you are running. Seth |
#6 |
Member#: 33990
How much of a Hp and TQ gain should I notice by installing the utec with these mods? JW and will I be able to tell the butt dyno difference seein as how there is no real dyno within bout 400 miles of me
#7 |
Member#: 7922
Probably +30/30 ish for HP and torque.
Really it will almost feel weaker because the car will run smoother. However you will definately notice how much faster you get up to certain speeds. Seth |
| Thread Tools | |
| Display Modes | |
| Can I get away with just the Stage 2 Map with these mods or is a Protune necessary? | Red Rexx | Factory 2.0L Turbo Powertrain | 13 | 11-16-2005 12:11 AM |
| Does anyone have the UTEC stage 2 + up pipe and IC hose map? | lawn boy | Engine Management & Tuning | 3 | 06-01-2004 01:30 AM |
| With these mods what stage Vishnu Chip will I need? | KnightWRX | Factory 2.0L Turbo Powertrain | 7 | 09-29-2003 12:38 AM |
| Will Vishnu Stage 1 re-map work with these mods? | Tweak-WRX | Engine Management & Tuning | 7 | 01-31-2003 12:19 AM |
| Will the Subaru 4/2-pot setup still work with the stock porto-spare? | Chunky_Chicken | Brakes, Steering & Suspension | 4 | 10-06-2002 02:14 PM |
