Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 03-14-2003, 10:32 AM   #1
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Post Software Sim USDM STi 1/4 mile Run
Bored at work I did a software simulated acceleration plot for the new STi. I know this is a guesstimate here were the parameters I usedů
Chassis Weight: 3254lbs.
Max Engine Speed: 7500 RPM
Torque (pound-feet)/RPM Pairs
(Based on average torque curves of similar 2.5l Turbo motors)
Torque RPM
1 140 2400
2 160 2600
3 180 2800
4 200 3000
5 220 3200
6 250 3400
7 260 3600
8 296 3800
9 300 4000
10 295 4200
11 290 4400
12 285 4600
13 280 4700
14 285 4800
15 280 5000
16 275 5200
17 270 5400
18 265 5600
19 260 5800
20 250 6000
Drivetrain
Gear 1 2 3 4 5 6 Final
Ratio (:1) 3.64 2.38 1.76 1.35 .971 .756 3.90
Drivetrian Torque loss: 20%
Clutch Slip Factor: 2
Shift Point
1-2 7000RPM Duration 500ms
2-3 7000RPM Duration 500ms
3-4 7000RPM Duration 500ms
4-5 7000RPM Duration 500ms
5-6 7000RPM Duration 500ms
Roll Out 10"
Launch 6000RPM
Results.....
Acceleration Simulator Results
Computing...
ET MPH Feet RPM Gear G Rear% Note(s)
0.01 0.31 0.0 6000 1 1.400 112.0
0.01 5.80 0.9 6000 1 1.391 111.6 *rollout*
0.25 13.13 4.2 6000 1 1.391 111.6
0.50 20.75 10.5 6000 1 1.389 111.5
0.75 28.36 19.6 6000 1 1.387 111.4
0.85 31.40 24.0 6042 1 1.386 111.4
0.86 31.56 24.4 6072 1 0.725 84.5
1.00 33.68 31.1 6481 1 0.664 82.0
1.21 36.40 42.0 7005 shift -0.018 54.3 *shift point*
1.25 36.39 44.1 7005 shift -0.018 54.3
1.50 36.29 57.4 7005 shift -0.018 54.3
1.55 36.27 60.1 7005 shift -0.018 54.3 *60 ft*
1.72 36.33 69.1 4571 2 0.577 78.5
1.75 36.71 70.8 4618 2 0.575 78.4
2.00 39.83 84.8 5011 2 0.564 77.9
2.25 42.86 100.0 5392 2 0.543 77.1
2.50 45.78 116.3 5760 2 0.523 76.3
2.75 48.56 133.6 6109 2 0.488 74.9
3.00 51.14 151.9 6433 2 0.453 73.4
3.25 53.53 171.1 6734 2 0.421 72.1
3.41 54.97 183.8 6916 2 0.402 71.3 *optimum shift pt*
3.50 55.66 191.2 7003 shift -0.026 54.0 *shift point*
3.75 55.52 211.5 7003 shift -0.026 54.0
4.18 55.38 231.9 7003 shift -0.025 54.0
4.25 57.60 252.6 5359 3 0.400 71.3
4.50 59.77 274.1 5560 3 0.391 70.9
4.53 60.03 276.8 5584 3 0.390 70.9 *60 MPH*
4.75 61.89 296.5 5758 3 0.383 70.6
5.00 63.95 319.5 5950 3 0.368 70.0
5.12 64.91 330.9 6039 3 0.361 69.7 *330 ft*
5.25 65.93 343.4 6133 3 0.353 69.4
5.50 67.82 367.9 6310 3 0.338 68.7
5.75 69.63 393.1 6478 3 0.324 68.2
6.00 71.37 419.0 6640 3 0.310 67.6
6.25 73.03 445.5 6794 3 0.297 67.1 *optimum shift pt*
6.50 74.62 472.6 6943 3 0.284 66.6
6.61 75.23 484.7 7000 shift -0.036 53.5 *shift point*
6.75 75.12 500.1 7000 shift -0.036 53.5
7.00 74.92 527.6 7000 shift -0.036 53.5
7.12 74.90 540.8 5345 4 0.295 67.0
7.25 75.74 555.2 5405 4 0.293 66.9
7.50 77.33 583.2 5519 4 0.289 66.7
7.60 77.96 594.6 5564 4 0.287 66.7 *1/8 mi (1)*
7.75 78.90 611.9 5631 4 0.284 66.6
8.00 80.45 641.1 5741 4 0.280 66.4
8.16 81.43 660.1 5811 4 0.277 66.3 *1/8 mi (2)*
8.25 81.97 670.9 5849 4 0.274 66.1
8.50 83.45 701.2 5955 4 0.267 65.8
8.75 84.89 732.1 6058 4 0.259 65.5
9.00 86.29 763.5 6158 4 0.252 65.3
9.25 87.66 795.4 6255 4 0.245 65.0
9.50 88.98 827.8 6350 4 0.239 64.7
9.75 90.27 860.7 6442 4 0.232 64.4
10.00 91.53 894.0 6532 4 0.226 64.2
10.25 92.75 927.8 6619 4 0.219 63.9
10.50 93.93 962.1 6703 4 0.213 63.7
10.75 95.09 996.7 6786 4 0.207 63.4
10.78 95.22 1000.9 6795 4 0.207 63.4 *1000 ft*
11.00 96.21 1031.8 6866 4 0.202 63.2
11.25 97.30 1067.3 6943 4 0.196 63.0
11.38 97.85 1085.9 6983 4 0.193 62.9 *optimum shift pt*
11.45 98.09 1096.0 7001 shift -0.053 52.8 *shift point*
11.50 98.04 1103.1 7001 shift -0.053 52.8
11.75 97.75 1139.0 7001 shift -0.053 52.9
11.96 97.56 1169.1 5007 5 0.195 62.9
12.00 97.73 1174.8 5016 5 0.195 62.9
12.25 98.79 1210.9 5071 5 0.193 62.8
12.50 99.85 1247.3 5125 5 0.191 62.8
12.54 100.01 1253.2 5133 5 0.191 62.7 *100 MPH*
12.55 100.06 1254.6 5136 5 0.190 62.7 *1/4 mi (1)*
12.75 100.89 1284.1 5178 5 0.189 62.7
13.00 101.92 1321.3 5231 5 0.187 62.6 *1/4 mi (2)*
Summary
0-60 mph: 4.71 Seconds
0-100 mph: 12.72 Seconds
60 ft: 1.55 @ 36.27
330 ft: 5.12 @ 64.91
1/8 mile: 8.16 @ 79.70 (81.43 actual)
1000 ft: 10.78 @ 95.22
1/4 mile: 13.00 @ 100.99 (101.92 actual)
Max Accel: 1.400 G
Air Density: 0.00231552 slug ft^3
Time Delta: 10.0 ms
DonA is offline
Old 03-14-2003, 10:43 AM   #2
spburns74
Member#: 24608
Nice launch RPM!!!!!!!!!!!! (6000 RPM)
MaxGrip
spburns74 is offline
Old 03-14-2003, 11:36 AM   #3
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
You don't perchance have the script / program available, do you? It might be fun to play with some numbers.
WRX_Mundi is offline
Old 03-14-2003, 12:02 PM   #4
Red-Impreza
Member#: 3884
Thumbs up
Cool script! How does it account for wheel spin? Is that included in the clutch slip factor?
Red-Impreza is offline
Old 03-14-2003, 02:32 PM   #5
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Here you go....
Accel Sim
Please go easy on bandwidth
DonA is offline
Old 03-15-2003, 12:46 AM   #6
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
Thanks for the use of the script. Some questions:
- I'm guessing axle ratio is really final ratio (3.9), not the rear ratio of 2.95, based on the rpms at a given speed I'm seeing.
- Any clues on the clutch slip factor? You used 2, it started out 0.8.
- I chose 3250 lbs, 0.33 Cd, 100in wheelbase, which we know from specs. I left the 10 ft^2 cross section alone since I don't know this. I guessed a 16 inch center of gravity -- the default seems far too low for a road sedan, and I'd guess 16 is still pretty low (though I really don't know). Based on the standard WRX, I changed to 40% of the weight on the rear wheels -- I have a strong suspicion the program assumes RWD since this kills the launches. We can fake extra traction by lying about the weight distribution or by lying about the tire friction. I'm not pleased with either.
- Tires: I chose 25.0 inches as that's what I think the 225/45-17s end up. Didn't change anything else. I'm guessing you changed the static friction since I get about 1g to start while you get 1.4gs.
It's been fun playing. We need to know the rev limit rpm (7000rpm redline, but where does it cut us off?) and the real torque curve. By then we'll have people running all these numbers on real cars though. It'll still give me something to play with regarding shift points and estimated effects of modifications (at least at the drag strip -- we need a autocross / track simulator next!).
Thanks!
Old 03-15-2003, 01:32 AM   #7
shoracer
Member#: 25247
0799 S60R RT/SC
Red/Purple B***H
Cool, but I like my GT3 simulation better. J/K thanks for the time and effort.
shoracer is offline
Old 03-18-2003, 02:54 AM   #8
Jaemmo
Member#: 5574
16 WRX
Does this sim give any top speed data?
Jaemmo is offline
Old 03-18-2003, 09:55 AM   #9
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Sure it does but without wind tunnel data it would be hard to get a accurate result
DonA is offline
Old 03-19-2003, 12:16 PM   #10
yellows2k
Member#: 16893
2002 Honda S2000
Spa Yellow
nice calculations don. my dog could of figured out that one. Just kidding. can't wait to smoke you in my s2000. ill give you a car and the break
MAtt
yellows2k is offline
Old 03-19-2003, 06:22 PM   #11
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Matt tell your woman to wash her ass after I roast your S I am going to pull over and pork her in my back seat
DonA is offline
Old 03-20-2003, 12:23 PM   #12
yellows2k
Member#: 16893
2002 Honda S2000
Spa Yellow
pork her with what. you have nothing to pork with. Kim told me
MAtt
Old 03-22-2003, 09:17 PM   #13
Jaemmo
Member#: 5574
16 WRX
Just read that the cd is .33. Can anyone punch up the top speed?
Jaemmo is offline
Old 03-22-2003, 10:28 PM   #14
Broeli
Member#: 2997
You have to add driver weight. Are you can to run the car on remote control or something?!
So, it would be more like 3450+ for the weight since the latest report for curb weight is 3275.
Broeli is offline
Agile Tuned 04 Sti - FP Red/Q16 1/4 mile run 04fpgreensti Proven Power Bragging 19 07-24-2009 04:23 PM
Stock 04 STi 1/4 mile runs bastich Proven Power Bragging 5 11-12-2005 12:25 PM
Stock turbo usdm sti 1/4 mile record. odin1 Proven Power Bragging 43 01-11-2005 11:31 AM
New WRX World Record 1/4 Mile Run CoByRS General Forum Archive 8 06-27-2000 04:38 PM
