Old 03-14-2003, 10:33 PM   #1
f1kichigai05
Member#: 31306
1989 FC3S Rx7 T2
Cinnamon Red
Default Lost almost ALL power. Engine and electronice problem, please help! i need my car
ok ok, ill give u the whole story in detail.Its long, but just bear with me. I have a 2000RS. My check engine light came on at around 20,000 miles. I was going around 45MPH one night and it just came on while i was driving. I decided to just drive with it and schedule an appointement with the dealer when i felt like it. There was nothing really wrong with the car except the check engine light and once in a while, the moment i cold started it, the engine would run for about 2 seconds and slowly rev down and die. The happened every once in a while so i wasnt really worried about it. I just drove it like that until i hit about 21,470miles. I got my Apexi n1 exhaust and put it on. I had a borla SS full cat back b4 and i replaced iit with the N1 full catback. Now ive hit 21,500 miles and all hell has broke loose. The weather has gotten warmer this week. 40's this week versus teens and 20's last week. My cars idle isnt steady. It revs up and down. Up 100rpm, down 100rpm. It just keeps on running like that. And when i try to move(like take off from a redlight), my car barely accelerates, until i hit about 3000Rpm and then it just moves like it should. But below 3000RPM, i almost have absolutly 0 power. It gurlgles alot more than i think is normal when in gear and slowing down form 3000 rpm. When i floor it, it sounds floored, but the car doesnt really move faster. I have almost no Torque below 3000 so taking off from 1st is a bitch. I gave it about 2000 going up my driveway like i always do but revs would just DROP and the engine almost stalled. sometimes while below 2500Rpm and giving gas, the power will suddenly kik in for like a half second and then it goes away right after. What the hell is wrong with my car. Is it an 02 sensor gone to hell? Belt skipped? O, and right at about 3100RPM, i get this annoying high pitch buzz out of the front left of my car. Exhaust leak? Rattling sheetmetal guard. It happed b4 i got my apexi put on. The guys bed on his pickup accidently oppend and a bottle of washer fluid came out, instead of flying off the road onto a bunch of rocks and gravel, i decided to try to go over it. Well it did, but the underpart of my car definitly crunched over it, not very hard, Sounded like crushing a aluminum can with your foot. The sound immediately developed form there. can anyone tell me what could be wrong with my car? id appreciate ANY help. thanks-alex
f1kichigai05 is offline   Reply With Quote
Old 03-15-2003, 03:24 AM   #2
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
Are all of your cylinders firing? Where in Michigan do you live, because I can pull a code for the CEL if you live close.
-Wes
RebelINS is offline   Reply With Quote
Old 03-15-2003, 08:48 AM   #3
f1kichigai05
Member#: 31306
1989 FC3S Rx7 T2
Cinnamon Red
i live in novi
Old 03-15-2003, 03:58 PM   #4
That Guy
Member#: 23212
2002 Impreza RS
Yeah, I'd say check if all the cylinders are firing. Had the same thing happen to me once, different car, and the plugs were fouled. Replacements and an oil change fixed it. Also had an ignition coil on the flake (it was a crappy car) and had similar things happen. Get the codes pulled soon!
And the cruching sound and rattle could mean that you broke something on the underside, body panneling or plastic or something. Or worse, you dented some of your exhaust plumbing. Crawl under and have a look.
That Guy is offline   Reply With Quote
Old 03-15-2003, 09:54 PM   #5
RebelINS
Member#: 2953
2000 Impreza 2.5RS
Like it says under my name, I live in Rochester, so if you want to meet up soon, send me a PM, and we can set it up.
-Wes
Old 03-15-2003, 10:09 PM   #6
kickin_81
Member#: 16679
2004 Forester XT
Did you get your O2 sensor replaced from the dealer yet? Way back when I hit my first CEL at around 25000 miles, it was the rear O2 sensor that went bad. The car would misfire, and drive like poo until you floor it... then it would accelerate normally. When you're WOTing the accelerator pedal, the ECU disengages most fuel-saving/air-fuel sensors and doesn't rely on the rear O2 sensor. Covered under warranty.
You should also check your spark plug wires for corrosion and loose connection.
kickin_81 is offline   Reply With Quote
Old 03-16-2003, 09:46 PM   #7
f1kichigai05
Member#: 31306
1989 FC3S Rx7 T2
Cinnamon Red
do the spark plug end caps on the wires have to be pulled off really hard? is seems like the round disk of rubber around the plug cap is like stuck onto the block or melted on or sumthing
Old 03-16-2003, 10:12 PM   #8
kickin_81
Member#: 16679
2004 Forester XT
Make sure your engine is cold. The metal from the engine will expand as well as the spark plug wires if the engine is hot or warm.
Old 03-17-2003, 01:05 PM   #9
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Yes, the plug wires are on very, very tight. I just did mine for the first time on my 01 RS and it took some effort, but all did come off ok.
jack
My paint looks dull- what is wrong with my car? thsiao Car Care & Detailing 36 05-19-2005 11:23 AM
Only [email protected] with 280who Dyno Dynamic, what is wrong with my car? sonicowrx03 Proven Power Bragging 41 06-24-2004 04:04 PM
What is Wrong with my car ? Jonnathan Normally Aspirated with bolt-on Forced Induction Powertrain 24 05-04-2004 07:36 PM
What is wrong with my car? REXchampman Tri-State Area Forum 5 11-26-2003 02:24 PM
What is wrong with my car? gnildronde General Community 12 02-04-2003 07:57 AM
