Old 03-14-2003, 10:50 PM   #1
Roy
Member#: 32241
1998 Impreza L Coupe
white
Question Amsoil and K & N Air Filters
Hi,
Long term, do either an Amsoil or K & N air filter cause problems with the MAF on a 98 Impreza 2.2 liter due to oil vapor from the air filter?
I have read some posts alluding to a potential problem with the MAF. Also know that some models of Mustangs have the problem.
Thanks for the help,
Roy
Roy is offline   Reply With Quote
Old 03-15-2003, 02:47 AM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
If it's over oiled they will cause problems (ie. hinder performance).
When I had an AMSOIL I first squeezed out the excess oil between a couple sheets of paper towels. Also did a wash and reoil a year later and no problems.
I also clean the MAF with an electronic cleaner a couple times.
Albert is offline   Reply With Quote
Old 03-15-2003, 11:11 PM   #3
Roy
Member#: 32241
white
Albert,
I noticed you said, "when I had an AMSOILl". What happened to it?
Was there any reason you did not like it?
From your response to my question I take it that the MAF will not be damaged provided there is not excess oil in the air filter (Ansoil or K & N).
Thank you,
Roy
Old 03-15-2003, 11:49 PM   #4
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Loved the Amsoil filter. When I use to check/clean the intake tubing there was never a film of dust that I always found when using gauze filters such as K&N. (No flame- K&N are good filters, they just let too much dust thru for my comfort)
I swapped in an Injen CAI a few months ago. The oe intake is in the attic with the Amsoil inplace just in case.
You have a '98 MAF so you should be ok, that baby is tough! I never had any problem when I had a Turn 3 intake or with the snorkle removed.
The '99's MAF from what I have read here were suspectible to one or a comb of vibration (MAF not firmly mounted), air turbulance, or oil build-up.
Originally posted by Roy
Albert,
Thank you,
Roy
Old 03-15-2003, 11:59 PM   #5
Roy
Member#: 32241
white
Outstanding! 8o)
Thanks again,
Roy
Old 03-17-2003, 10:05 AM   #6
99OBSter
Member#: 14324
1999 OBS 4eat
I've had an K&N panel for 70K miles with no problems. Just replaced it with a K&N cone filter.
I like K&N alot.
99OBSter is offline   Reply With Quote
Stock Air Box w/ K & N Air Filter phuhs04 Engine/Power/Exhaust 13 04-20-2008 03:49 AM
Just replaced my K & N air filter with the STi high flow one SubZombie Newbies & FAQs 11 02-26-2004 03:17 PM
K & N Air Filter in WRX? WRC-Go Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-10-2002 11:39 AM
K & N Air Filter Im'Pat'za Normally Aspirated Powertrain 2 02-07-2001 09:03 PM
