Old 03-14-2003, 11:56 PM   #1
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
Default Head Gasket
i have a 01 rs with 63k on it and my head gasket is just starting to go, i have plenty of time to fix it but i would like to replace it with a better quality gasket. I don't want to change the compresion ratio at all, it will have a turbo in it by July but i am going to tune the car and get it running good on low boost with stock internals first then pull the motor and do internal mods. so i want a head gasket that can take maybe 4 or 5 pounds of boost. does anyone know where i can get these gaskets and how much they are.
THANX,
Bryan
bryan2.5rs is offline   Reply With Quote
Old 03-15-2003, 01:05 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cometic Gasket (maybe dot com). They have OEM spec gaskets and the abilty to make any custom gasket you want. The prices aint bad either.....
Jay Storm
www.sourcemotorsports.com
Old 03-15-2003, 09:30 PM   #3
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
Default bump
bump
Old 03-16-2003, 03:52 AM   #4
azdan
Member#: 20159
2001 RS
From what I understand a stock RS motor can with stand 5 lbs. of boost reliably. I wouldn't go any higher but allot of people run 5 lbs. for a long time. I would ask in the Aftermarket Forced Induction forum.
azdan is offline   Reply With Quote
Old 03-16-2003, 05:31 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Unhappy
You're welcome.....
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 11:16 PM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 11:19 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 12:08 PM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 11:22 PM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 12:40 PM
