Old 03-15-2003, 12:57 AM   #1
WRXVII
Member#: 15854
VF34'd...
Lightbulb Help! How did you guys install vishnu unichip with PNP adapter???
How can I install it so that the PNP adapter does not block the ECU cover? I just can't find the way to cleanly install it. I ended up installing it without the metal ECU protective cover 'cause PNP adapter was on the way..... can someone post a pic of way to cleanly installing the Vishnu unichip?
I just love the way my car drives with the chip .... it makes huge difference in every gears!
When I first installed it and went out for a drive, CEL blinked 3 to 4 times then went away. Is this normal?
WRXVII is offline   Reply With Quote
Old 03-15-2003, 01:48 AM   #2
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
You need to get standoffs so the floor plate sits 1/2 - 3/4" higher but then there is plenty of room.
I get CELS whenever I hit it hard (either on the track or on a twisty piece of road when I am really doing the WOT to brake back to WOT). The cell I get is misfire - the EMI adapter fixes this problem. I also had rough running around 100-120 in 4th and 5th gears but the EMI adapter fixed this too.
Good Luck!
AntiochCali is offline   Reply With Quote
Old 03-15-2003, 01:59 AM   #3
tdxflex
Member#: 13634
you can just buy longer bolts and some nylon spacers. that's what i did. the bolts i got are like 25mm or 30mm long, threading is m6 x 1.0. then i got 1" long nylon spacers and cut them down a bit to fit between the ecu plate and mounting brackets. i couldn't justify the $25 or whatever it costs for the special metal spacers.
tdxflex is offline   Reply With Quote
Old 03-15-2003, 02:05 AM   #4
WRXVII
Member#: 15854
VF34'd...
Good Luck!
That is not a good news!. Is it a normal problem with Vishnu unichip??? How can you manage to install unichip, PNP, and EMI all together in that tight spot?
Old 03-15-2003, 07:29 AM   #5
Avedis
Member#: 8171
2005 WRX STi
Blue / Gold
--jeff
Avedis is offline   Reply With Quote
How did you guys get over the long relationship with your highschool sweet heart Christoff Off-Topic 90 05-02-2005 10:22 AM
Cheap: Vishnu Unichip with PnP rexxer Private 'For Sale' Classifieds 8 11-08-2003 02:20 PM
How did you guys install your components on the doors? slammedWRX Car Audio, Video & Security 2 02-20-2003 10:33 AM
How did you guys put the 3/16 connector in? Dark Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-13-2002 08:30 PM
How did you guys replace your plugs on a MY99??? Xscreamer Normally Aspirated Powertrain 6 03-14-2001 02:57 PM
