Old 03-15-2003, 01:18 AM   #1
DocDetroit
Member#: 24977
2003 WRX
Default Rev-lite T-Sport shift light
I wanted a shift light but hated the the look of the flash-light style lights. After doing a little research I can across the t-sport by rev-lite. It's a tiny sequential shift light.
It has 6 LEDs. 4 are red, and 2 are green. The 6 LEDs cover a 1,000 RPM range. I have it set so the first red LED comes on at 6,000 RPM and the last green LED comes on at 7,000 RPM adjustment is done with a thumb wheel.
I mounted mine on top of my gauge pod. I drilled a tiny hold just behind it to run the wires into the pod. I tapped power and ground where my gauges wire in. I brought the RPM signal up from the ECU. It took me less than an hour to install it.
The LEDs are amazingly bright for being so small. I was really worried about mounting it on the gauge pod. I wasn't sure if I'd see it while concentrating on the road. Because the last two LEDs are green, you don't have to worry about trying to count how many LEDs are on.
If you can't tell, I'm really impressed with it. It's a great shift light, and it's so small and unobstrusive no-one will notice it unless you get in that 6 - 7K rpm range.
http://www.rev-lite.com/rev.html
DocDetroit is offline   Reply With Quote
Old 03-15-2003, 01:22 AM   #2
neverendingmods
Member Sales Rating: (1)
Member#: 23796
2006 STi
white
I've been thinking about this one. Which wire near ecu did you tap(location and color).
Thanks,
Eric
neverendingmods is offline   Reply With Quote
Old 03-15-2003, 01:25 AM   #3
DocDetroit
Member#: 24977
2003 WRX
Check out http://www.northursalia.com/m...ng/wrxpin.html
I used block #136, pin #9.
Rev-Lite sequential shift light White 2.5rs Private 'For Sale' Classifieds 9 06-03-2006 01:18 PM
T-Sport shift light install help wkderf Electrical & Lighting 2 05-05-2004 09:50 PM
T-Sport Rev-Lite installed Butt Dyno Electrical & Lighting 13 03-23-2004 02:30 PM
FOR SALE: WRX OEM parts + T-sport Rev-Lite shift light dookiebob Tri-State Area Forum 1 03-29-2003 10:21 PM
Questions about T-SPORT Rev-Lite/Shift Light T-SPORT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-17-2002 08:57 AM
