Old 03-15-2003, 12:39 PM   #1
Spangaru
Member#: 17817
2006 Baja Turbo
Unhappy Rattle in the Random Tech Cat
I have an increasingly louder rattle from my Random Tech high flow cat. After some close inspection, it is definitely coming from inside the unit, it's not just a rattling heat shield or hanger issue. I've done a search and found at least one post about a somewhat similar problem, but couldn't really tell from that what the problem was. Has anyone had this problem, and is there a way to fix it?
Thanks,
Spangaru is offline   Reply With Quote
Old 03-16-2003, 02:24 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yeah replace it, the bonding has come loose on the cat and it's bouncing around in there.
jeremy
Old 03-17-2003, 04:55 PM   #3
Spangaru
Member#: 17817
2006 Baja Turbo
Exclamation You are correct!
I pulled the cat out this weekend, and bouncing around is an understatement. Although the element seems to still be captive in the unit (it won't come out), it is definitely not still connected to anything. It sounds like a large rock rattling around in there. I'm only surprised that the rattling noise while it was on the car wasn't worse. I guess it was just that I couldn't hear it most of the time over the sound of the exhaust. It had gotten progressively louder.
We'll see how the idea of a return is treated by the vendor. I got the cat as part of a COBB power package.
Thanks,
Old 03-18-2003, 04:05 PM   #4
Merc
Member#: 15929
07 CTS-V
slick silver
Had the same problem with mine. The reason is the honey-comb inside is falling apart. You can either hollow it out or get a new one. I went and hollowed it out. Now the c/e light is on all the time. Been like that for over a year. Makes a wicked backfire too ... But get it done soon because it will go down your exhaust and stall out your car. Good luck
Merc is offline   Reply With Quote
Old 03-18-2003, 07:18 PM   #5
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Default That post you referred to may have been mine.
I dont like the quaility or the service of random Tech.
Mine did the same thing, they're junk($300 worth). I still have it and its hollowed out or should be by now (I removed the pieces out of my muffler, lol). Its gives a tinty sound which not sure I like to much. But I definitly tell a difference over stock now thats its hollowed out. And man, You want to talk about LOUD. I have the stromung SS cat back with dual tips and it sound like a race car. (HEHE) Let me know If you have any other questions.
sti27 is offline   Reply With Quote
Old 03-18-2003, 11:16 PM   #6
Spangaru
Member#: 17817
2006 Baja Turbo
Arrow OK so far
All these things sound familiar. I had the same loud exhaust that you described; CEL and backfires too. I didn't even realize just how loud until I put the stock cat back on. Unfortunately, hollowing out the cat is probably not really an option if I want to keep it on for yearly smog inspections. It did pass the first one with no problem other than the need for a little extra warm up time.
On a positive note, I got quick replies from COBB and RandomTech that they would treat this as a warranty issue. We'll see how that progresses and if it results in some sort of repair or a complete replacement.
Thanks again for the replies.
Old 03-19-2003, 01:00 AM   #7
joefocker20
Member#: 13745
2015 STI
Default Re: That post you referred to may have been mine.
Did you gain more performance after the catalyst broke apart and fell out?
joefocker20 is offline   Reply With Quote
Old 03-19-2003, 03:31 PM   #8
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
joefocker20- Its does seem to have more performance after the fact but it sounds alittle tinty but not all the time(weird). I had no cel problems though.
Old 03-20-2003, 01:50 AM   #9
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
...get metallic substrate cats and you'll never have this problem
Albert is offline   Reply With Quote
Old 03-20-2003, 09:21 AM   #10
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
the new random tech are metallic...
DanzBorin is offline   Reply With Quote
Old 03-20-2003, 11:00 AM   #11
Spangaru
Member#: 17817
2006 Baja Turbo
Question Since when?
I just packed up mine for return under the warranty. I'm wondering if the new one will be different than the original that I'm returning (purchased about 10 months ago). If so, maybe I'll reinstall it. If not, I may opt to sell it in anticipation of putting on a turbo that wouldn't be compatible with the cat anyway.
Old 03-20-2003, 01:23 PM   #12
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Correct, so I've heard.
Does your insuniate that it is the newer metallic Random Tech's that are falling apart?
Any firsthand reports of problems with the newer metallic RT cats?
Borla header + Borla cat-back + Random Tech Cat = Teh sexy noise! Fred Zaplitny Normally Aspirated Powertrain 11 04-17-2003 10:21 AM
The sound of a hollowed out Random Tech Cat? Bob O Normally Aspirated Powertrain 0 03-19-2003 12:26 PM
Random Tech Cat Yebisu69 Normally Aspirated Powertrain 12 04-09-2002 10:14 AM
Random tech Cats SUCK!!! NateDogg Normally Aspirated Powertrain 14 11-20-2001 08:26 PM
Where to get a Random Tech cat? mcu81 Normally Aspirated Powertrain 3 08-04-2001 08:06 PM
