Old 03-15-2003, 06:57 PM   #1
BlackBeastie
Member#: 11846
13 A5
Default change oil filter with every oil change?
I am kind of stuck. i went to get a new filter and oil and the guy gave me the wrong filter. It was at napa and he crossreference the purolator part and ended up giving me the wrong filter. Anyway, i am stuck here until i get a new filter because i am half way through the job. Can i reuse my old filter or is this not advised? Thanks for any help.
BlackBeastie is offline   Reply With Quote
Old 03-15-2003, 07:29 PM   #2
Karl
Member#: 13110
If you can't get a filter now because you are without a car, just reuse the old one. Get a new one when you get back to the part store, just change the filter without changing the oil. You are going to spill a little oil, so just put a drain pan beneath the filter when you unscrew it, and make up the difference with some fresh oil. Check dipstick to see how much oil you need.
Don't worry, your oil will not all come out.
Karl is offline   Reply With Quote
Changing AT oil/filter and differential oil juvenescence Service & Maintenance 6 06-17-2009 02:49 PM
Is PureOne Oil Filter = Quaker State Oil Filter?! Gambit Vancouver Impreza Club Forum -- VIC 4 11-24-2006 02:39 AM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
synthetic oil and changing the filter with out draining the oil warpspeedwrx Service & Maintenance 16 07-21-2003 11:16 AM
Trasko oil filter with heat sink TerenceT Service & Maintenance 1 03-12-2002 07:42 PM
Message Board Statistics All times are GMT -4. The time now is 04:13 AM.
