Old 03-15-2003, 08:28 PM   #1
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Default any dyno proven gains for STi hood scoop?
I have searched for sti hood scoop dyno air and various combinations and haven't found anything. I'm just curious if it will matter w/ the stock TMIC or if you have to have a bigger one in order to see any gains (or if there is no gain whatsoever other than more pebbles in the engine)
-bd
Old 03-15-2003, 08:45 PM   #2
Member#: 13004
2002 Pump Gas Homo
Nope no ButtDyno gains to be had.
David@Vishnu is offline   Reply With Quote
Old 03-16-2003, 01:46 PM   #3
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
There really isn't going to be any hp gains by adding the hood scoop, but in normal driving it will keep your intercooler closer to ambient temps. I did some research last summer with STI scoops, and air diverters and water spray kits and such (I think the thread was Air intake temps in the FFI forum). There ended up being some good info in that thread (along with the useless rambling).
Russ
WRX1 is offline   Reply With Quote
Old 03-16-2003, 02:02 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
Found it - muchos gracias
http://forums.nasioc.com/forums/show...ghlight=intake
-bd
Old 03-16-2003, 04:11 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
I doubt you'll find any description of "dyno proven" gains since most dyno measurements are conducted with the hood up.
Jon [in CT] is offline   Reply With Quote
Old 03-16-2003, 04:23 PM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
touche Jon.
supermarkus is offline   Reply With Quote
Old 03-16-2003, 11:06 PM   #7
Ken C
Vendor
Member#: 6605
Default thoughts
A few other things about the STi scoop to think about -
Over about 125 mph, the air wave on a car with a normal stance (no rake angle due to front lowering, yadda yadda) will begin to clear the standard scoop. The STi scoop helps there if you are driving your car on track (or in Montana )
Second, if you do get a scoop with a real STi splitter, you'll also notice a fitting for the water spray on the splitter. You can disconnect the washer hose from the passenger washer nozzle, and plug it into that nipple. Voila, instant water spray on track days - just wash the windshield.
The problem is that the STi splitter is made to match up to an uprated intercooler, and is too large to mate up to the standard without some creativity.
Ken
Rally Performance
ScoobySport
Ken C is offline   Reply With Quote
Old 03-17-2003, 04:29 PM   #8
zacek
Member#: 19467
02 WRX
WR Blue
Default Re: thoughts
good point, this is indeed very important and often overlooked fact. Is is very important for the splitter's rubber duct to mate just right into the targeted intercooler, without bulging nor uncovered parts. If there is a big gap somewhere, a big part of the air being injected inot the scoop will just divert into that part instead of forcing itself thru the IC.
zacek is offline   Reply With Quote
Old 03-17-2003, 09:43 PM   #9
Ken C
Vendor
Member#: 6605
Exactly - that's the issue. Well said - the air will take the least resistance around the IC without being confined by the splitter well.
KC
Old 03-17-2003, 10:46 PM   #10
Bolster
Member#: 22290
2002 WRB WRX Wagon
I saw my oil temps drop slightly- which is probably a result of more air hitting the intercooler (lower air charge temps mean lower overall operating temps).
Bolster is offline   Reply With Quote
Trade WRX hood scoop for STi hood scoop silverWRX_02 NESIC Private Classifieds 2 09-02-2006 09:10 PM
WTT wrx hood scoop for Sti hood scoop psm DemonPossessedNinja Private 'Wanted' Classifieds 0 06-08-2006 02:38 AM
WTT CGM WRX hood scoop for STI hood scoop elohdaeh78 Tri-State Area Forum 0 01-04-2006 04:22 PM
wtt wrx hood scoop for sti hood scoop SinisterSkube Private 'Wanted' Classifieds 2 10-19-2005 11:55 PM
Performance gains from sti hood scoop? IndyRacer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-12-2002 10:46 PM
