Old 03-16-2003, 09:47 PM   #1
six6sicks
Member#: 28876
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default CEL only at idle
I've been having my CEL come on since I put my exhuast on. I never noticed a pattern to it until now. It seems to only happen when I warm my car up in the A.M. Then it only goes off after I drive it for a few days. The pattern seemed to start after I installed my ProECM.
Any thoughts on what it might be. Maybe something just needs to be adjusted?
six6sicks is offline   Reply With Quote
Old 03-17-2003, 10:32 AM   #2
Pocon
Member#: 17479
1999 Impreza WRX
Silverthorn Metallic
You better get that code check with a scanner. Not enough info to diagnose anything.
Pocon is offline   Reply With Quote
Old 03-17-2003, 10:07 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
I'll put $50 that its code p0130....I get it all the time when I let my car warm up in the morning for a bit.
sidewayz is offline   Reply With Quote
Old 03-17-2003, 11:15 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
My bet is that your TPS is not adjusted or functioning properly and your IDLE switch is what causes the cel.
Old 03-19-2003, 11:35 AM   #5
Pocon
Member#: 17479
1999 Impreza WRX
Is the TPS located at the left hand side of the TB? If that's so how can it be adjusted? I suffer from code P1507; idle control system malfunction.
cel flashes at idle?? gleesamo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-06-2007 01:59 PM
thin white smoke coming from exhaust only at idle wrx21 Newbies & FAQs 6 12-06-2006 10:26 PM
sb swap misfire only at idle rexnprogress Subaru Conversions 2 10-09-2006 02:26 AM
UTEC: CEL on at idle...goes away after moving waveoff Engine Management & Tuning 3 07-19-2004 11:53 PM
AVCS CEL... only at idle!!! (Own3d again) MK19_ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-13-2004 05:28 AM
