Old 03-17-2003, 09:09 AM   #1
99OBSter
Member#: 14324
1999 OBS 4eat
Default Yet another ram air
See what boredom and a warm weekend will get you?
99OBSter is offline   Reply With Quote
Old 03-17-2003, 09:10 AM   #2
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Does the foil make it faster?
DanzBorin is offline   Reply With Quote
Old 03-17-2003, 09:12 AM   #3
99OBSter
Member#: 14324
1999 OBS 4eat
Nope, just ghetto,m which is why a ripped it all off. Well, sorta, the stuff can be a PITA to get off.
Old 03-18-2003, 07:42 AM   #4
99OBSter
Member#: 14324
1999 OBS 4eat
Default 1999 MAF intake
I'm posting this in case anyone does a search.
I used a Kartboy adapter, which I think is a little over priced for an aluminum tube, but what they hey, it's the only thing out there and the workmanship is good. I also used a K&N filter that I bought at KNfilters.com. I got the biggest one that would fit in my car, which was a little too big. It hits my ABS module. Eventually I'm going to get a smaller filter.
Taking off the old air box was supper easy. It's only held on by two bolts. The MAF attaches to it with 4 small bolts.
The hardest part were making the braces. I wanted to make sure the MAF wouldn't wobble around at all, so I went out to Lowes and got a piece of metal that was about 6 feet long and 1" wide. I then chopped it to size with a hacksaw and hammered it into shape with a vice. A couple of holes and the fit was great. I'm very pleased with the whole look. For once, something I did to my car actually looks good!
As far as gains, I'm very pleased. Lost some low end, but gained some high end. In 1st, my car screams to 6K rpm. And the sound? Grrreeeaaaatttt!!!
I think I will put the vent cover back on to prevent water from getting into the filter. The filter's oiled, but don't want to take any chances.
Old 03-18-2003, 08:10 AM   #5
BoyRacer
Member#: 31411
2001 RSTi, Cayman S
BRP Subaru, Black Cayman
Default confused
I'm confused... Is this really a "Ram Air" setup? I thought it was only called "ram air" if you had air blowing into the intake. Since your not even piped into the fender, I don't think this is even a cold air intake. It's just an intake right? You sould get better flow and sound out of it, but no "ram air" or cold air advantages.
Am I missing something? I often do.
MGB
BoyRacer is offline   Reply With Quote
Old 03-18-2003, 08:42 AM   #6
99OBSter
Member#: 14324
1999 OBS 4eat
Yeah you're probably right, but just wait until i get my snorkel in from the hood scoop to the air filter. That damn hood scoop might actually be marginally functional!
Old 03-18-2003, 08:54 AM   #7
BoyRacer
Member#: 31411
2001 RSTi, Cayman S
I'm planning to plumb my hood scoop into my intake too. That will be real ram air.
MGB
Old 03-18-2003, 10:05 AM   #8
danci1973
Member#: 19018
1995 Legacy Wagon
Default Re: 1999 MAF intake
I have a very similar setup, however instead of covering the fender hole, I made aluminum heat shield to stop the heat from the engine. Since I don't have fog lights I cut the plastic that was there and installed a mesh grill instead. This should get plenty of air into the fender and into my filter - it may even be pressurised...
The temperature difference right after stopping is huge - hot on the engine side and cool on the filter side - and it even increases after sitting a couple of minutes.
I haven't had a problem with water or snow yet.
D.
danci1973 is offline   Reply With Quote
Old 03-18-2003, 10:32 PM   #9
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Heat or not to Heat
I heard an interesting point the other day about heat shields within the engine compartment. Although I will not remove my stock filter box, I'm going with the silencer removal and Amsoil panel set-up; I probably would make a heat shield because I'm meticulous like that. Anyway, this guy told me that under the hood temperatures only rise when sitting still and who needs HP then? As you start moving, colder and denser air will make its way into the engine compartment. Just another point of view, thatís all.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 03-18-2003, 11:20 PM   #10
joefocker20
Member#: 13745
2015 STI
Have you ever stopped and felt your intake after driving, the suckers pretty hot.
joefocker20 is offline   Reply With Quote
Old 03-19-2003, 02:37 AM   #11
danci1973
Member#: 19018
1995 Legacy Wagon
I guess the heat shield / CAI stuff really works as my sucker doesn't get nearly as hot as before, when he was sucking hot air.
D.
Old 03-19-2003, 07:19 AM   #12
99OBSter
Member#: 14324
1999 OBS 4eat
Yeah, I was looking in the compartment and wondering how to make a heat shield. Haven't come up with an easy way. Anyone got pics of theirs?
Old 03-19-2003, 09:33 AM   #13
Pocon
Member#: 17479
1999 Impreza WRX
Silverthorn Metallic
Adding a CAI means sacrificing low end, where the EJ25 is pretty good at compared to the low compression EJ20. I was thinking of making a DIY intake but most of my driving is city so I need the low end grunt. Ideally, I would like to come up with a system which switches without too much hassle from a CAI to stock airbox. Just in case I go lapping or touring.
99OBSter, did you loose low end power by removing the air filter box?
Pocon is offline   Reply With Quote
Old 03-19-2003, 10:30 AM   #14
99OBSter
Member#: 14324
1999 OBS 4eat
I did lose a bit of low end. But, really, not as much as I thought I would. I guess that torque box thingy actually works ok. My car can still beat any comparible car off the line.
I basically kept everything stock except the air filter itself. Same piping, same plastic plenum "resevoir" behind the throttle body, etc.
Old 03-19-2003, 10:42 AM   #15
BoyRacer
Member#: 31411
2001 RSTi, Cayman S
Actually he didn't remove the air filter box. You can see it in the top picture partly wrapped in tin foil.
I saw that he said he lost a bit of low end, but I don't think he actually did. Does he have any numbers or is he just using his buttdyno? From what I can see he just attached a filter to the end of his stock intake system and (hopefully) took out the stock panel filter, oh ya, and added a bunch of tin foil. I'd say that this would make a very small performance improvement with ZERO loss of low end torque. Also it probably makes more noise since he's removed some of the muffling crap.
MGB
Old 03-19-2003, 10:45 AM   #16
99OBSter
Member#: 14324
1999 OBS 4eat
Boy Racer, there isn't an air filter in the box behind the throttle body in a 1999 OBS. That's only in MAP 2000+ cars and cars in california. So the air intake you see is THE air filter for the car. Which is why you can gain a bit of HP by doing this. Not saying a lot, but maybe a little.
And of course I'm using my butt-dyno. No 4WD dynos in good ole Dayton!
Old 03-19-2003, 10:50 AM   #17
BoyRacer
Member#: 31411
2001 RSTi, Cayman S
Oh right, I forgot, no panel filter to worry about, cool.
The fact remains you've left the air box attached to the throttle body. This is where the low end torque could be lost, but won't be in your case since it's still in place.
MGB
Yet another threat about yet another boring work day Mad06STi Off-Topic 5 10-04-2007 11:48 AM
anyone tried a ram air setup yet? [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-23-2003 04:21 PM
Anybody Have True Ram Air Intakes Available Yet? MY99 2.5GT Normally Aspirated Powertrain 12 08-23-2001 11:54 AM
Another ram-air tune-up. HamFist Normally Aspirated Powertrain 4 08-19-2001 12:24 PM
Cold-air/Ram-air intake from hood vent (not scoop)? Fred Fredburger Normally Aspirated Powertrain 31 03-21-2001 11:13 AM
